Lost vape triade question
Viking Vapes
Mine seems to be set the closest it can be from the box when I put the actual watt hours in for the battery's the battery meter seems to be way off reading like 84% on fully charged batteries where as the stock settings from factory it goes to 97%. Set to 26.48 watt hours from factory
Here's my way of setting watt hours when using 18650's instead of 3S lipo pack, I use 87.5% of the rated mah.
My reasoning for this is the lipo packs get their mah rating from approx 3 - 4.2 volts while the 18650's are rated from 2.5 to 4.2 volts.
The calculator built into Escribe is meant for the lipo pack.
Just my way though.
