yoseff Posted August 9, 2016 Author Report Share Posted August 9, 2016 Usually i just clean it wit a swab, but from time to time i like to clean it very well, so i use metal cleaner in the swab. Is it ok to use also contact cleaner, or it can harm something there? I also noticed that sometimes the central pin gets a bit dry and will not work at its best. What could be a good lubricant to put there? Or is it something to avoid? I have some dielectric paste that stands high temperatures. Putting just a bit of that in central pin (where it slides - not on top) may be good idea? I already used that on mechanical mods (it was part of solution with my stingrays sticky button) but this is a totally different beast Some silicone spray could be an option too? I wanted something that lubricates but do not interfere with current or resistence.Thanks in advance for your advices Link to comment Share on other sites More sharing options...
black lace Posted August 9, 2016 Report Share Posted August 9, 2016 I stuff tissue in mine to clean the female threads and scratch the top of the centre pin with a sharp screwdriver,,, when the centerpin has become sticky, (like jamed in the bottom of the 510, and not springloaded) i have lubed it with a single drop of motor oil, then worked it ip and down with tweezers, then swabed up any exess with moor tissue, . Most 510 connectors have some kind of seal in there so you should be ok, nothing should run into the mod.. Link to comment Share on other sites More sharing options...
