My battery bar is showing empty on my VT133 and checked the batteries on device monitor and still have 3.69v. Seems as if as soon as it drops below 3.7 the bar is empty. Will keep trying it with the bar at 0 for a while since I know it still has power.
I calculate my watt hours a little different than most when using 18650's in a mod meant for a lipo pack, this is due to the built in (hardware) cell cutoff
So I'm using Steve's battery CSV with a soft cell cutoff of 2.9 volts and 12.5% subtracted from the 18650's advertised mah.
My battery icon as far as accuracy seems pretty good. But I'm using LG HD2's not 30q's.
Oh BTW the hard cutoff on a DNA200 is 28.5 volts unless that got changed by a firmware revision......in case anyone is wondering.
Well battery bar issue fixed again thanks to Steve. I had to DL the .csv battery profile for the LGHG2 load it on my device and now my battery bar is working and showing between 1/3 and 1/2 instead of empty. Thanks Steve your a life saver. Or mod saver.
