2legsshrt Posted September 27, 2016 Author Report Posted September 27, 2016 My battery bar is showing empty on my VT133 and checked the batteries on device monitor and still have 3.69v. Seems as if as soon as it drops below 3.7 the bar is empty. Will keep trying it with the bar at 0 for a while since I know it still has power.
dwcraig1 Posted September 27, 2016 Report Posted September 27, 2016 See if you can get a measurment of the voltage drop when firing in Device Monitor when firing with the batteries standing at 3.7 volts.
dwcraig1 Posted September 27, 2016 Report Posted September 27, 2016 Certainly nothing excessive going on there.
dwcraig1 Posted September 27, 2016 Report Posted September 27, 2016 I calculate my watt hours a little different than most when using 18650's in a mod meant for a lipo pack, this is due to the built in (hardware) cell cutoff So I'm using Steve's battery CSV with a soft cell cutoff of 2.9 volts and 12.5% subtracted from the 18650's advertised mah.My battery icon as far as accuracy seems pretty good. But I'm using LG HD2's not 30q's.Oh BTW the hard cutoff on a DNA200 is 28.5 volts unless that got changed by a firmware revision......in case anyone is wondering.
2legsshrt Posted September 27, 2016 Author Report Posted September 27, 2016 OK then my 2 LG HG2's would be 19.425 at that calculation.
2legsshrt Posted September 27, 2016 Author Report Posted September 27, 2016 Do you think after I put that number in I should do a soft reboot??
dwcraig1 Posted September 27, 2016 Report Posted September 27, 2016 just upload to device for sure, perhaps a hard reboot.
2legsshrt Posted September 27, 2016 Author Report Posted September 27, 2016 OK but I notice that a hard reboot you lose all your settings soft it saves your settings.
dwcraig1 Posted September 27, 2016 Report Posted September 27, 2016 You will lose the atomizer's cold setting with a hard reboot, your settings will stay.....not like default settings.
2legsshrt Posted September 27, 2016 Author Report Posted September 27, 2016 Battery bar still reads empty and batteries at 3.62v. I wonder if I got a bad one or what is going on.
2legsshrt Posted September 27, 2016 Author Report Posted September 27, 2016 You couldn't ask for a better temp regulation it is almost a perfect straight line with SS316L. Very accurate but the battery bar is really bothering me.
2legsshrt Posted September 28, 2016 Author Report Posted September 28, 2016 Well battery bar issue fixed again thanks to Steve. I had to DL the .csv battery profile for the LGHG2 load it on my device and now my battery bar is working and showing between 1/3 and 1/2 instead of empty. Thanks Steve your a life saver. Or mod saver.
