DNA133 won't wake up unless usb connected.
Subohmn
Built a 133 with a 2s lipo and once it goes into sleep mode it won't wake up unless I plug in the usb, after it's unplugged it'll work fine unless I let it go back into sleep mode. If it matters, escribe is seeing 4.2v in cells 1 and 2 and 1.12v in cell 3. It is set to two cell mode and I have cell 2 and 3 bridged at the board. Solder joints are good and I've tested at pad 3 with a meter and it's even with cell 2 (obviously). Battery is an 1800 mah maxamps. If anymore info is needed just lmk.
this sounds like an RMA issue to me. "board not waking up unless USB inserted" it's been quite a while since i've seen a post with this problem. how old is this board? i would open a help ticket with evolv. in the meantime, you could try re-flashing the firmware etc. here's the help ticket link......
https://helpdesk.evolvapor.com/index.php?a=add
Flashed a few times, even went back to the appropriate version of escribe to do it. I didn't pay attention to the "get info" to see the age but it's a flawless mod I converted for someone so I assume it's pretty old.
