a1 Posted October 20, 2016 Author Report Posted October 20, 2016 I have 3 sdna75s and just one of them has a strange issue with the 510.When I screw an atomiser on it screws down all the way but has a slight rattle after the atomiser is fully seated,there is also a little bit of give - ie: I can turn the atomiser a couple of mm back and forth even though the atomiser is fully connected.It`s almost as though the threading on the 510 is too "loose" if that makes any sense.The same atomiser(s) do not have the problem on the other two sdna75s - they screw down and stay still, no rattle.Any smart ideas how to fix this without returning the unit ?ThanksEdit: Putting a thin o-ring between the mod and atomiser base works, but it`s not very graceful, leaving a gap and being a bit of a nuisance.
dwcraig1 Posted October 20, 2016 Report Posted October 20, 2016 Sounds to me like perhaps the nut that holds the 510 body into the case may be loose.https://youtu.be/g5fwz_SsqIU@ 23:40 there is a good view of it.
a1 Posted October 20, 2016 Author Report Posted October 20, 2016 Thanks DWCraignow i`ve seen it`s comparatively easy to access, I`ll check that out and make sure it`s tight.Edit: Hallelujia - that fixed it.I wouldn`t have guessed it was that as there seemed to be no give in the main 510 fitting itself, at all.A very hard quarter turn of the nut seems to have solved it though, Thanks Craig !Edit 2: I have to add, that although it cured the problem, it didn`t do it as I would have hoped.I don`t think the 510 was loose at all, but tightening up the 510 nut has pulled the connector right in, so much so that the base of the atomiser is now touching the top of the device and friction alone against the rubberised coating is holding it still.Rather that hadn`t happened as I would have liked to have kept the top of the device free of wear and scratches from screwing atomisers on & off.
