Hey folks,
So, I have a Lost Vape Therion that has somehow stopped charging via USB over the past few days. The device connects to escribe fine and the batteries inside are paired and discharging evenly (Samsung 25R's, tried 2 paired sets, same issue).
I've tried a soft/hard reset, cleaned all mod/battery contacts and usb port with 70% ISO and tried various cables. Occasionally the status light will turn green even though the device is nowhere near fully charged.
Does anyone have any solutions before I contact Lost Vape?
  • 4 weeks later...
Have you checked to make sure that USB charging is enabled?
Under Device Monitor click on Diagnostics, and Turn on USB Charging. It may be shut off for whatever reason on yours. The Therion does in fact charge Via USB. Mine is actually plugged into my Work PC Charging as I type this.
