XanderII Posted November 9, 2016 Author Report Share Posted November 9, 2016 Hi Guys,Got my Hcigar VT75 last week. But I do not satisfy the way it vapes. I have a .23ohm build.I set the wattage in 65 watts, but its going down to 37 watts while puffing.My battery (LG LG 18650 HG2) is fully charge.I cannot get enough clouds. Its so annoying. It's a expensive device but im very dissapointed.The mod is too hot after 8~10 puffs.If anyone uses VT75, please guide me on how it performs well.Please help!Best Regards. Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 9, 2016 Report Share Posted November 9, 2016 What is the material that the coil is made from?Where on the mod get hot? Link to comment Share on other sites More sharing options...
XanderII Posted November 9, 2016 Author Report Share Posted November 9, 2016 +dwcraig1The coil is Kanthal A1. build in Ijoy ComboThe Mod get hot almost all sides. Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 9, 2016 Report Share Posted November 9, 2016 Clean the threads on the battery cap and it's corresponding threads, I suspect your problem is there. Also if using EScribe Device monitor you can see if you have a really big voltage drop on the battery (because of a bad connection, ect.) Link to comment Share on other sites More sharing options...
XanderII Posted November 9, 2016 Author Report Share Posted November 9, 2016 +dwcraig1Thank you for the info.But my unit is new and clean. Arrived last week but I used it yesterday.If there is a voltage drop. How can I fix it?Thank you for the response Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 9, 2016 Report Share Posted November 9, 2016 https://forum.evolvapor.com/topic/66308-topic/?do=findComment&comment=896028https://forum.evolvapor.com/topic/66601-topic/?do=findComment&comment=898810Have a look at this. Link to comment Share on other sites More sharing options...
XanderII Posted November 9, 2016 Author Report Share Posted November 9, 2016 +dwcraig1thank you for the info. I will try that option.By the way I have "weak battery" warning.Is there any specific batteries that I need to use.I only used LG Choco 18650 HG2. I don't have 26650 yet. Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 9, 2016 Report Share Posted November 9, 2016 That battery if authentic should be fine. Set your cell soft cut off to 2.7 volts. A bad connection from the battery will result with that warning as well as a low battery. Clean the threads anyway even if they look clean. Link to comment Share on other sites More sharing options...
XanderII Posted November 9, 2016 Author Report Share Posted November 9, 2016 +dwcraig1Thank you I'll done cleaning it. And the result is the same.When I remove the battery, its almost blistering.Maybe it's the battery is the problem. How do I check the battery if it is legit or not?Can you suggest me a couple of battery brands?ThanksBest Regards. Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 9, 2016 Report Share Posted November 9, 2016 LG HD2 or LG HD2C or Sony VTC5AIt's certainly possible that it is the battery Link to comment Share on other sites More sharing options...
