The box works fine as is. A battery profile makes the meter more accurate. Why would you want 2 different profiles? Only 1 can be active at a time, and in order to to use the 2nd, you'd have to hook up to escribe, and load the other profile.
P.S You can run the battery analyzer for YOUR batteries right there within escribe which will generate the perfect curve for YOURS in their current state.
Why do you need the .ecig file? Are you saying the mod values are blank for your 'inbox', or your profiles are blank?
