Ethrem Posted December 1, 2016 Author Report Share Posted December 1, 2016 I was wondering what the safe board temp is. My Triade hits 129F while charging with a 5V/2A charger (its a DNA 250). Since this thing is such a tight fit with my batteries, I just charge them in the mod rather than have to rewrap the batteries literally every time I charge them (Samsung 25Rs - apparently this mod is made specifically for LG HG2s, right down to the battery door not sitting flush with the 25Rs and the very tight fit) but I don't want to chance the board frying from getting too hot. I'm assuming that 129 is the safety threshold and that the board can handle higher temps than that but I wanted to make sure. My room isn't exactly warm (about 65F right now) so I don't know why the board temp goes so high. I'm not using a mod wrap or anything...And yes, I know the optimum choice is to go get HG2s but I'm tapped out at the moment and can't really just run and buy 6 new batteries, especially when my 25Rs work perfectly fine. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted December 1, 2016 Report Share Posted December 1, 2016 the 250 creates more heat while charging than the DNA 200. i usually see around 115-120F while charging at the full 2 amps. there are temp safety limits built into the DNA 250 that will protect the board, batts, and more importantly you, i wouldn't worry too much about it. from what i've been seeing/hearing, the 250 runs around the 110-125F while charging (at 2 amps).as for batteries not fitting properly in the sled, maybe there is something on the door you could shave down for better fit. dunno. Link to comment Share on other sites More sharing options...
