Hi guys, I have a bit of a weird problem with one atty (limitless RDTA) on my hcigar vt75 and can't figure out what's causing it. The Ohm reading is all over the place, sometimes it displays the temp with ridiculous numbers (E.G. 344986F) and jumps out of temp mode (off). I've got it setup with 317l ss using the same profile as on my dna200 and the atty works perfectly on the 200 and all my other atomisers work perfectly on the dna75. The coil obviously isn't shorted anywhere neither is the atty as it's fine on the 200. The 510 is definitely making contact so I'm at a bit of a loss as to what's happening! Any ideas on what to try?
Almost certainly a connection issue, is that the one where the outer of the 510s unscrews, is so take it off and clean the threads and if there is a screw or two near the battery cap give them a tweek.  It could also be loose board mount screws or in the atty.
Thanks for the advice Vaping Bad! Took the whole device to pieces and cleaned all contacts and threads with alcohol, it's back to behaving again.
