Markyt123 Posted December 17, 2016 Author Report Posted December 17, 2016 I have a question which might be dim. I've run wire wizard with the coil spec I've built. The ohms generated is .6 on wire wizard I've installed 2 coils which reads .31 on my DNA 250. My question is; is the .6 ohm csv I've taken from wire wizard ok to install onto escribe even though with 2 coils the mod reads .3. Furthermore, does it make that much difference from the standard ss316 profile already installed?
Spector NS5 RD Posted December 19, 2016 Report Posted December 19, 2016 it should be fine to use. there might be little to difference in the vape from either profile. whatever you like best, use.
Dampmaskin Posted December 20, 2016 Report Posted December 20, 2016 Was the 0.6 Ohm figure for a single coil? If so, it makes sense that a dual coil will read close to 0.3 Ohm.In any case, the TCR will be unaffected.
Markyt123 Posted December 20, 2016 Author Report Posted December 20, 2016 Excellent! Thanks for the response. Learning as I go!
