Etné Posted December 30, 2016 Author Report Posted December 30, 2016 Hi guys,I received a Therion 75 and when I try to do a battery test under Escribe with a coil of 1 ohm with 24Ga kanthal at a power of 40 watt I have this message "Ohm to high" Is it normal? Should I make a lowercoil ? Trying the test with less Watt? I found this info for a dna 200 but I'm not sure if this is the same for a DNA75I found various CSV for my battery (SAMSUNG INR 18650-25R) but most of time there is one or 3 batteryin the box. Did it change something.I have 2 battery in my TherionThanks for your answer.
VapingBad Posted December 30, 2016 Report Posted December 30, 2016 You need a resistance less then or equal to 0.5 ohm to get full power, for 40 W you should be able to use 0.9 ohm. It is the output voltage limit of 6.2 V that determines the max res at any power setting, there is a graph in the specsheet or you can calculate by (6.2 * 6.2)/power.
