aslibanget Posted January 4, 2017 Author Report Share Posted January 4, 2017 hallo all,,,, i have some problem with my vt75,,, indicator show different variable ohm between the other mod, with the same atomizer,,,, example : i using Serpent mini + Ni80 coil,,, on other mods ( pico, dagger , triade, ) i get 0.31 - 0.33 ohms, but on my VT75 i get 0.41 - 0.47 ohms,,,, i need help for solving the problem,,,,,,,thx b4 all Link to comment Share on other sites More sharing options...
VapingBad Posted January 4, 2017 Report Share Posted January 4, 2017 If that is the one where the outer of the 510 unscrews take that off and clean the threads, if that is the one with one or two screws next to the battery cap check they are snug. It is almost certainly a ground problem just a case of checking, cleaning and tightening connection points. Link to comment Share on other sites More sharing options...
aslibanget Posted January 5, 2017 Author Report Share Posted January 5, 2017 VapingBad said:If that is the one where the outer of the 510 unscrews take that off and clean the threads, if that is the one with one or two screws next to the battery cap check they are snug. It is almost certainly a ground problem just a case of checking, cleaning and tightening connection points.i has cleaning,,, but doesn't fix the problem,,,, T_T Link to comment Share on other sites More sharing options...
