Temp control not working
bryanferd26
How's it going I will try and point you in the right direction but need some information what device are you using DNA? Second what material are your coils and do you have E scrib for example I am using custom Opus DNA 250 with Boreas RTA titanium coils .087 build and it's wonderful I understand stand you have a smok baby I believe but what coils kanthal stainless steel titanium
I think its clapton wire. the coil thats comes with the box. I read somewhere that clapton is made of kanthal and does not support temp control. I'm planning to buy a new coil that supports temp sensor. Can you advice me some wires? Thank you guys. Im still new to my mod and still exploring. btw my mod is therion 133 with dna200.
Hi People,
I'm currently facing this same issue. I'm currently using HCigar's VT75 with DNA 75. Using OBS Engine 25 with SS316L 26 gauge wire. I coil my wire in space, approximately around 7-8 wraps. Recently around 3 weeks ago, I began to notice that each time I set a temperature, it goes back to power mode with watt. I remember not having this problem in the past. I then connected to Escribe to configure the temperature, still the same problem existed. Eventually when I vape, it goes erratic in between Power mode to Temperature more erratically. The ohms is also going erratically high to low when it's in temperature mode. Have anyone experienced this problem yet. I'm in the verge of changing my mod to a different brand. Can I get some help? I am confused, whether is it due to the chip or battery. Btw I am using AWT 26650 battery. Please help...
igor30 said:
Hi People,
Try unscrewing the 510 connector from the vt75 and give it a good clean and refit, also give your atomisers 510 a good cleaning. This sorted mine out.
  • 3 weeks later...
My 10 cents worth it's not allwas a loose connection some of RTA on the market now can not read ohms properly at all .know your build if it fails to match up . I learned if a build of .08 reads .1 I don't even wast my time or if the 510 pin on the RTA floats forget it .08 .09 makes big difference. So if your .1 build is reading .13 and you have checked everything try a different RTA .I use wire profile from evolv TI on my DNA 250 /200 and they work great.I build for friends and there are well knowing RTA That I will not touch my two favorite are Boreas and the Griffin I am sure there are many more
