rom.oconer Posted March 1, 2017 Author Report Share Posted March 1, 2017 pls someone help me, i have a therion 166 with vtc6 batts. the first time i try to connect my device with my usb the battery meter is charging, i connected it to escribe. then i must have clicked something in escribe. now if i disconnect my therion and turn it on, the screen only says the - evolv dna 250, then it shut downs. and when i connect it again in usb the battery meter wont charge, not unlike the first time i try to connect it via usb it charges. pls help me what seems to be the problem? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted March 1, 2017 Report Share Posted March 1, 2017 will the device power on if you press and hold in the fire button for while? what are your 3 cell voltages in Device Monitor? Link to comment Share on other sites More sharing options...
rom.oconer Posted March 1, 2017 Author Report Share Posted March 1, 2017 yes it does turn on if you hold the fire button. yes it has 3 cell volts, how can i change it? Link to comment Share on other sites More sharing options...
giz_60 Posted March 1, 2017 Report Share Posted March 1, 2017 The Therion 166 only uses 2 cells...if you are seeing 3 cells in Device Monitor, you need to go to the 'Mod' tab & make sure that the battery is set for 2 cell...then upload to device... Link to comment Share on other sites More sharing options...
rom.oconer Posted March 1, 2017 Author Report Share Posted March 1, 2017 i cant change the 3 cell to 2 cell. it cant be clicked. it says 9 in the capacity, but the cell i cant open it its unclickable Link to comment Share on other sites More sharing options...
giz_60 Posted March 1, 2017 Report Share Posted March 1, 2017 Ok...at the very top of the screen, go to 'Options>User Interface & click on 'Manufacturer'...then you should be able to change the cell number Link to comment Share on other sites More sharing options...
rom.oconer Posted March 1, 2017 Author Report Share Posted March 1, 2017 ive changed it. what should be the value of capacity and cell soft cutoff? Link to comment Share on other sites More sharing options...
giz_60 Posted March 1, 2017 Report Share Posted March 1, 2017 19.96 for 2 VTC6's Wh's & 2.8 cutoff...here is the .csv file for the battery curve..download the file...load .csv & chose the file you just downloaded....you will have to manually enter the Wh's though... Sony_VTC6 (2)_18650_3000 mah_19.96 Wh.csv Link to comment Share on other sites More sharing options...
rom.oconer Posted March 1, 2017 Author Report Share Posted March 1, 2017 other settings below okay? or do i have to change anything else? Link to comment Share on other sites More sharing options...
giz_60 Posted March 1, 2017 Report Share Posted March 1, 2017 That should be it for the battery... Link to comment Share on other sites More sharing options...
rom.oconer Posted March 1, 2017 Author Report Share Posted March 1, 2017 thanks for the help man, bout the lost vape load screen. i lost mine, you have file of that? is max peak iput current 28A okay r shoud i change? Link to comment Share on other sites More sharing options...
giz_60 Posted March 1, 2017 Report Share Posted March 1, 2017 Yes...28 on both of those is ok.... Link to comment Share on other sites More sharing options...
