I can't vape on any of my newer takes, TFV8 TFV12 Ruex etc.
When I press the fire button it flashes "Kanthal Max Power" on the display.
I don't know which device you have, what wattage you are trying to vape at, and etc.  So this is just a quick thought....
In escribe under the mod tab under electrical you can see what the kanthal max power limit set to.....it may need to be adjusted depending on which device you have, the wattage maximum it can achieve, your coil build and wattage requirements, and other things.,  Start there.... my best thought without more info from you....
