?????? ????? ???? ??? ??? ?? ????, ??? ??? ????? ?? ?????? ??????, ? ?????? ????? ???? ????. ???????? ??? ? ???: ???? ?????????? ??????????? therion 166, ? ??? ? ??? ??????????, ??? ??????? ?????? ?????? ????? 50% ??? ????? chek battary, ????? ?????, ?????????? ??? ??? ????? ????????????, ? ??????? ????? ???????? ?????????.
Check cell soft cutoff
In device monitor check voltage drop under load (firing), see if one or both cells drop below cell soft cutoff.
Make sure battery connection are clean, even if they look clean.
Interesting: note on my snip my cell soft cutoff is 2.91.
I was setting it to 2.85 and upon upload it would change to 2.91.
I now set it to 2.8 and it stayed at 2.8.
I hope the OP got it sorted
I've noticed that on other parameters as well...seems to round to a different value...:crazy:...
(dw corrected dw's spelling)
?????? ???????, ???????? ?????? ???????? 2.91 ? ??? ????? ??????, ?? ????????? ?????? ????????, ??? ??????? ?????? ??????? 50% ???? ????? ??????? ????????, ???? ?? 115Watt, ? ????????? ?? 85watt, ??? ????? ??? ?? ???????? ??? ?????? ????????
giz_60 said:
.13 ?? ??? 115 ???? = 4.1v ... ???????? ?????? ???????...?????????? ????? ?????
Opps ???? ... ??? 3,8 ?????, ? ?? 4,1 ... ?? ??????? ???????, ????
Provided the batteries are of good quality and all connections (sled, soldering) are good there should be no problem down to 3.65 volts area.
What cells are they. Tried others yet?
% is to vague...need standing voltage and sagged voltage.
He's gonna try a different set of batteries...
