mixmasterjay Posted February 24, 2017 Author Report Share Posted February 24, 2017 hi all this is my 1st post here but what a great forum basically i have my freinds black edition therion 166 here and it says check battery after a little knock while it was usb charging , i finder 167 did the same but i re installed the firmware from here and its been perfect ever since (thankyou ) , now this doesnt want to work , just says "check battery " , these are my own checked and fully charged batteries and i know they work 100% and are fine in the finder 167 please heeeeeelp much appreciated jay 1 Link to comment Share on other sites More sharing options...
giz_60 Posted February 24, 2017 Report Share Posted February 24, 2017 Have you checked the battery contacts? Make sure that both of the - buttons have good pressure against the battery... Link to comment Share on other sites More sharing options...
mixmasterjay Posted February 24, 2017 Author Report Share Posted February 24, 2017 yeah both are very strong Link to comment Share on other sites More sharing options...
giz_60 Posted February 24, 2017 Report Share Posted February 24, 2017 What are your battery levels reading in Device Monitor?Edit: Also, verify that the battery settings in the Mod tab are still set for 2 batteries... Link to comment Share on other sites More sharing options...
mixmasterjay Posted February 24, 2017 Author Report Share Posted February 24, 2017 cell 1 0.05cell 2 4.93 to 4.94 cell 1 is the same on on 3 sets of batteries :/ Link to comment Share on other sites More sharing options...
giz_60 Posted February 24, 2017 Report Share Posted February 24, 2017 I would try a soft reboot, and if that doesn't work, try a hard reboot...Save your .ecig file first... Link to comment Share on other sites More sharing options...
mixmasterjay Posted February 24, 2017 Author Report Share Posted February 24, 2017 i have also put my finder 167 software on and its still the same , so i redid the therion 166 firmware Link to comment Share on other sites More sharing options...
mixmasterjay Posted February 24, 2017 Author Report Share Posted February 24, 2017 tried both them reboots too and nothing has changed with it Link to comment Share on other sites More sharing options...
giz_60 Posted February 24, 2017 Report Share Posted February 24, 2017 Hmmm....sounds like the 'knock' has knocked loose a battery connection internally, either at the battery sled or at the board. If the device is still in warranty, I would try contacting Lost Vape...http://www.lostvaperepaircenter.com/.... Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 24, 2017 Report Share Posted February 24, 2017 The bad: When ever one of the cells is reading higher than 4.2 volts it's time for a new board. You will have to decide how /who will take care of it. For sure Evolv will send you a new board through the ticket system, they may let you send the entire mod (don't know) but try Lost Vape 1st. Link to comment Share on other sites More sharing options...
mixmasterjay Posted February 24, 2017 Author Report Share Posted February 24, 2017 ah i suspected as much , thankyou so much for your help guys i appreciate it Link to comment Share on other sites More sharing options...
brienzee Posted March 15, 2017 Report Share Posted March 15, 2017 I'm getting the same issue. It started between puffs, I don't recall knocking the mod at all. Link to comment Share on other sites More sharing options...
mixmasterjay Posted March 19, 2017 Author Report Share Posted March 19, 2017 we ended up sending it back to the retailer for them to send a new one out Link to comment Share on other sites More sharing options...
Aleorocha Posted August 7, 2017 Report Share Posted August 7, 2017 I was able to solve the problem of my updating through the file therion166.ecig Therion166.ecig Link to comment Share on other sites More sharing options...
ivanperalta13 Posted September 2, 2017 Report Share Posted September 2, 2017 It happened to me the same after resetting it in escribe. There's a solution? in the lower left, in device monitor says ... normal mode, in another mod says mode charging. as can be changed.? Link to comment Share on other sites More sharing options...
