bluntmoment Posted April 14, 2017 Author Report Posted April 14, 2017 DNA 250 screen glitch? I have 3 little bars - - - in between ohms and volts on my screen. cant seem to correct this. any ideas? never have seen this before on any other of my DNA 250 devices
giz_60 Posted April 14, 2017 Report Posted April 14, 2017 Double check the connection of the screen ribbon to the board...make sure it is properly aligned in the socket...
bluntmoment Posted April 14, 2017 Author Report Posted April 14, 2017 ok ill check that out, shitty part is that I expoxied the damn thing in already w/ the board holder to the enclosure. Didn't see it on test fire before mounting, must have pulled out some during installation, thank you for your help!
bluntmoment Posted April 14, 2017 Author Report Posted April 14, 2017 i put my tfv8 on there and now i notice the ohms are jumping. possible the 510 isn't tight enough or is this because i might not have the screen in all the way?
giz_60 Posted April 14, 2017 Report Posted April 14, 2017 Smok TFV atty's are known to cause issues due to the floating pin in the base...especially in TC mode...I got rid of all mine because of the floating pin..nothing but a PITA...although it could be an issue with the 510 as well, but....and the screen issue shouldn't have anything to do with it...
bluntmoment Posted April 17, 2017 Author Report Posted April 17, 2017 thank you, I am gonna take it all apart tonite and check the screen. Any secrets to pushing in the ribbon to make sure it goes all the way in? it seems I can get it a little more than half way in. Thanks again for your help.
giz_60 Posted April 17, 2017 Report Posted April 17, 2017 Not sure if you have seen this, but this is taken from the 250 data sheet.... 250 Screen Insallation.doc
bluntmoment Posted April 17, 2017 Author Report Posted April 17, 2017 yassir, thank you for all of your help.
