giz_60 Posted April 20, 2017 Report Posted April 20, 2017 The .csv is the discharge profile. You will have to manually enter the Wh's & cell cutoff... and then be sure to upload to device...
Meerk4t Posted April 20, 2017 Report Posted April 20, 2017 thanks anything else to configure in batteries?also can i charge for the first time new batteries with USB? i don't have any external charger like nitecorealso is there any difference for your .csv and JimScotty0 's .csv?
giz_60 Posted April 20, 2017 Report Posted April 20, 2017 Max Peak Input Current & Max Sustained Input Current should be 28... first time charge with USB may or may not work, depending on cell voltage & if they are close to being balanced...I wouldn't do it, but thats me...
Meerk4t Posted April 20, 2017 Report Posted April 20, 2017 giz_60 said:Max Peak Input Current & Max Sustained Input Current should be 28... first time charge with USB may or may not work, depending on cell voltage & if they are close to being balanced...I wouldn't do it, but thats me...just thank you for the useful information!
klaz Posted April 21, 2017 Report Posted April 21, 2017 also is there any difference for your .csv and JimScotty0 's .csv?what about this question??i have run mine vtc6 and giveme 29,09.and why you put so low your cut off in 2,75?i think the safer is 2,8 and up.
giz_60 Posted April 21, 2017 Report Posted April 21, 2017 klaz said:also is there any difference for your .csv and JimScotty0 's .csv?QUOTE]The 2 are very close...according to his post, he had only run his cells through 1 charge/discharge cycle...it can take several cycles to wake the cells up to their max potential, but, depending on circumstances, you will probably never find any 2 .csv generated with the battery analyzer exactly the same...[QUOTE=klaz]what about this question??i have run mine vtc6 and giveme 29,09Understand that these settings are only going to help the battery indicator on the device to be a bit more accurate...has no effect on the battery life or run time. Again, depending on circumstance, you will probably never find any 2 Wh's generated with the battery analyzer exactly the same...use what works for you!klaz said:and why you put so low your cut off in 2,75?i think the safer is 2,8 and up.2.75 is a safe value for the cell soft cutoff for the 18650's, but if you feel 2.8 is safer, then by all means...this is only a cell SOFT cutoff value, where the board will throttle back the wattage & you will get the Weak Battery message(flashing battery indicator)...IIRC, for safety reasons, the board will shut down at 2.5v & you will get the Check Battery message...The higher you set the cell soft cutoff value for, the sooner the board will start throttling back the wattage...
mojlepque Posted June 8, 2017 Report Posted June 8, 2017 Hi! Do you have maybe the discharge profile for 2 x sony konion vtc6 batteries? I use them with a DNA250 (Lost Vape Therion 166). Capacity 21,6 Wh Cell Soft Cutoff 3,2 V Max Peak Input 28A Max Susteined Input 28A Are these correct?! Thank you!!!
Rorence Posted June 9, 2017 Report Posted June 9, 2017 Teach us more in this field. After reading on here, we can learn more in this topic.
