fecti
Everything posted by fecti
  1. should work with the latest escribe version now, let me know.
  2. Version 4.6
    420 downloads
    Featuring meticulously crafted icons and a bright damascus steel style background, providing high contrast and visibility, this custom designed DNA60c Theme gives you access to all the essential settings with minimal menu diving. Menu buttons on the Main Screen allow for fast access to the sub pages (Coil, Settings and Info). For ease of use, every screen (except Info) has a Status Field explaining what each icon / field does. Focusing on Replay and Temp Control (Session not available), the Coil and Info Screens change based on the selected Profile (of course you can use it if you're a wattage vaper, too!). The Coil Screen let's you measure Cold Ohm and adjust everything Preheat and Boost related on one page. I even added Preheat Power for Temp Control (must be higher than base Watt to work). The Main Screen also displays information about your last puff (Live Ohm, Voltage, Current and Puff Time). Additional information about the last puff (Power, Temperatures) is displayed on the Info Screen when in Temp Control Mode, in Replay/Watt Mode the Board and Room Temperature is displayed instead. Available in Portrait and Landscape orientation. Thank you for using this Theme! Full list of features: Main Screen - Battery - Power - Temperature (Temp Control) - Replay off/on (Replay) - Go to Coil Screen - Go to Settings Screen - Go to Info Screen - Live Ohm - Last Puff Voltage - Last Puff Current - Last Puff Time Coil Screen - Measure Cold Ohm - Coil Cold Temperature - Boost off/on (Replay/Watt) - Preheat off/on (Temp Control) - Replay Warmth (Replay) - Preheat Power (Temp Control) - Preheat/Boost Punch (Replay/Watt and Temp Control) Settings Screen - Select Profile - Screen Direction - Temperature Unit - Display Brightness - Stealth Level - Max Puff Time - Clicks to Lock Device Info Screen - Total Puffs - Last Puff Power - Board Temperature (Replay/Watt) - Room Temperature (Replay/Watt) - Last Puff Temperature (Temp Control) - Last Puff Peak Temperature (Temp Control) - Battery Voltage - Battery % - Version and Service Pack (Landscape only)
