alsk1
Everything posted by alsk1
  1. You can set a clock or date in escribe but the DNA60c will not showing it. Wether date or time
  2. Thank you very much! I will give it a try! 👍
  3. Hello, I own a DNA60c and I'm having a problem where the mod locks itself after a certain amount of time (key lock). "Auto Lock when idle" is disabled in Escribe. This only happens with firmware 1.1 SP84; it doesn't happen with firmware 1.1 SP75. With 1.1 SP84, it happens daily, practically every time I vape; the key lock is active again the next time I try to vape. For this reason, I'm using 1.1 SP75 again.
  4. What exactly do you mean? There is no new software and firmware since months....
  5. Hello! I have a problem with the DNA60c regarding the puff counter. After the battery has been changed, the puff counter resets. This is the total puff count. As an example: Puff Count = 178. After changing the battery: Puff Count = 111 Or Puff Count = 195, after changing the battery Puff Count = 27 Is it a software error or a hardware error?
  6. Ok ok.... I'm using Dicodes Resistherm wire but selected is "Watt Mode" in the profile, yes. Is there no possibility so say that the temperature is visible in replay mode (in the theme itself) ? It does make no sense for me to hide the temperature in Replay (Watt) Mode. I'm asking because i had it that the actual temperature was visible on the display and in the Live Monitoring of the Escribe Software in Replay Mode (with Watt selection). But i don't know what i did in the theme.... i changed it and now it doesn't work anymore.
  7. I'm using a Temp sensitive Material (Dicodes Resistherm) and i'm using Replay Mode.... This is probably not the reason for my problem. My Theme is Evolv Standard Theme, Not a customize Theme. 😞
  8. Hello, as you can see in the photo, on the lower right the temperature is suddenly missing. All 3 marks are set when i click on the diagram screen. I dont know why suddenly the temperature disappeared. I tried to install the firmware again, another firmware, another theme... nothing helps. The temperature is gone and i don't know why. In the theme its still there and i changed nothing. Instead of the red curve (temperature) i have 2 green lines and don't know what this means.... 😞
  9. The screenshot was to show in which menu it happens. You can't see the problem on it, because i deleted the double names (original and shortened) and imported the files with short filenames....
  10. I use the DNA75c
  11. I found an error in the Escribe Software. But my english is not the best to explain.... If you import a new Coil Material with a long filename (e.g. "Nife30_Resistherm_TCR_SteamEngine_xxxx.csv it works... But when you download the settings from the mod, the name of this material is changed to "Nife3" and this Material is double in the mod under both names (old name and new name).
  12. Fire Button + Up-Button does not work here (DNA75c)
