ghu-mtl
Everything posted by ghu-mtl
  1. Obrigado pela informação! vou atualizar!
  2. obrigado pela informação vou atualizar!
  3. Version 1.0.0
    264 downloads
    simples e funcional com modo replay! by: ghumtl
  4. yes I'm not able to load either, I'll do what you said and then I'll give you a feedback, thank you friend! helped me a lot!!
  5. VID-20210724-WA0065.mp4
  6. Can you use it safely?
  7. Are you using it like this? Where do I put the screw? In one of the negative cells down?
  8. thank you for sure i want and i will do it!!
  9. I have a triad and I would like if there is any way to use it with two batteries, if there is any specific configuration in escribe
  10. I'm going to do it here and see if anything changes, thank you very much for now!! I will do the tests
  11. thank you so much for replying! it started after I tried to change the theme, it happens with all colors, green is pink and vice versa, black is white, everything is inverted
  12. I'm having problems with inverted colors in my therion, will it resolve to do this?
  13. I have a problem here also on therion dna75c, the colors are reversed, how can I solve it? does it have to do with the contrast?
  14. Helo! I'm facing a problem with my therion 75c, the screen color is inverted, I put the odin theme and the skull turned green, the original theme is different too, where blue is white, the I've reversed the screen and the buttons and it didn't work, can someone help me? I apologize for the bad English!
  15. managed to solve W I have the same problem here with therion 75c
