            AmadVaper
                Posts30
AmadVaper's Achievements
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Works perfectly on Linux Mint 21 5.15.0-101-generic! (After installing gtk-sharp2 lol)
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware James do you have a link to the latest version?
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Getting the something similar on Linux Mint (SetupEScribe2_SP50_US.run) about a missing dependency for gdk-sharp although I am not able to find this package on the nets: DISTRIB_ID=LinuxMint DISTRIB_RELEASE=21.2 DISTRIB_CODENAME=victoria DISTRIB_DESCRIPTION="Linux Mint 21.2 Victoria" NAME="Linux Mint" VERSION="21.2 (Victoria)" ID=linuxmint ID_LIKE="ubuntu debian" PRETTY_NAME="Linux Mint 21.2" VERSION_ID="21.2" HOME_URL="https://www.linuxmint.com/" SUPPORT_URL="https://forums.linuxmint.com/" BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/" PRIVACY_POLICY_URL="https://www.linuxmint.com/" VERSION_CODENAME=victoria UBUNTU_CODENAME=jammy cat: /etc/upstream-release: Is a directory michael@Machine:~/Desktop$ uname -a Linux Machine 5.15.0-89-generic #99-Ubuntu SMP Mon Oct 30 20:42:41 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux michael@Machine:~/Desktop$ /home/michael/.local/opt/evolv/escribe-suite/launch-escribe-suite 08:26:45.0712: System.IO.FileNotFoundException: Could not load file or assembly 'gdk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' or one of its dependencies. File name: 'gdk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' at A.VCB.OB () [0x00027] in <02501018e92a42c1bc00a2481203f98d>:0 at A.MSU.OP () [0x00034] in <bcb6d587fc2648aea61a95388d1199af>:0 at A.MSU+<>c.VP () [0x00000] in <bcb6d587fc2648aea61a95388d1199af>:0 at A.MSU.NP (System.Boolean , System.String ) [0x0017b] in <bcb6d587fc2648aea61a95388d1199af>:0 HRESULT: 0x80070002 Unhandled Exception: System.PlatformNotSupportedException: Operation is not supported on this platform. at A.MSU.NP (System.Boolean , System.String ) [0x001b0] in <bcb6d587fc2648aea61a95388d1199af>:0 at A.ZP.ZP (System.String[] ) [0x00011] in <bad52511b36f4caea115464997ece0df>:0 [ERROR] FATAL UNHANDLED EXCEPTION: System.PlatformNotSupportedException: Operation is not supported on this platform. at A.MSU.NP (System.Boolean , System.String ) [0x001b0] in <bcb6d587fc2648aea61a95388d1199af>:0 at A.ZP.ZP (System.String[] ) [0x00011] in <bad52511b36f4caea115464997ece0df>:0
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware No issues at all here. Applied update all working normally for my 3 dna250c mods.
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Hello immelman, So for installations I have done in a VM, in Manjaro Escribe gets installed to /home/user/.local/opt/evolv/escribe-suite - you "should" be able to run launch-escribe-suite. If you are asking about running SetupEScribe2_2020-06-22_US_test.run chmod the file to your user and execute it: ./SetupEScribe2_2020-06-22_US_test.run
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Got it. I will set this and see what the logs say after some time. Thank you @James for all your help the past few days!
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Pretty sure I did a full wipe and OS install when I picked up the NVME last year. It's obviously not as new as the OS on the B550 which I believe is Mint 20.3 Not sure what you mean about errors when connecting... do you mean usb or network? I did a grep of dmesg for you. I did see this in the syslog but that was added by their driver and not me. systemd-udevd[619]: /etc/udev/rules.d/60-brother-mfp-brscan5-1.0.2-2.rules:17 Invalid key 'SYSFS'
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware 60-dimension_engineering.rules KERNEL=="hidraw*", SUBSYSTEM=="hidraw", ATTRS{idVendor}=="268b", MODE="0660", GROUP="plugdev", TAG+="uaccess", TAG+="udev-acl" KERNEL=="ttyACM*", SUBSYSTEM=="tty", ATTRS{idVendor}=="268b", TAG+="uaccess", TAG+="udev-acl" 99-hidraw-permissions.rules KERNEL=="hidraw*", SUBSYSTEM=="hidraw", MODE="0664", GROUP="plugdev" I guess the only real difference is that my rule isn't tagging or adding the ttyACM rule.
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware No. pkexec is there but I do remember having issues with pkexec where it would not run as some applications had pkexec in their run statement, but I could run the statement in the terminal just fine. /usr/bin$ ls pkexec* pkexec pkexec --version pkexec version 0.105
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware getfacl /dev/hidraw2 getfacl: Removing leading '/' from absolute path names # file: dev/hidraw2 # owner: root # group: root user::rw- user:michael:rw- group::--- mask::rw- other::--- Sorry... forgot this /etc/udev/rules.d$ ls 52-airspy.rules 99-hidraw-permissions.rules 60-brother-mfp-brscan5-1.0.2-2.rules 99-md380.rules 60-dimension_engineering.rules rtl-sdr.rules 60-vboxdrv.rules So 60-dimension_engineering.rules are there
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Sweet. So I added a udev rule to force hidraw devices to be root:plugdev. Connected and downloaded without issue on the X470 I created 99-hidraw-permissions.rules under /etc/udev/rules.d with this line: KERNEL=="hidraw*", SUBSYSTEM=="hidraw", MODE="0664", GROUP="plugdev" Serial Number: JAFAxxxxxxxxx Firmware Version: 1.1 SP46 INT Firmware Date: 2021-12-28 Revision Code: 311104658 USB Vendor ID: 268B USB Product ID: 0419 USB Product Version: 3.0
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware On the B550 ls -la /dev/hidraw5 crw-rw----+ 1 root plugdev 239, 5 Apr 26 13:08 /dev/hidraw5 On the X470 ls -la hidraw2 crw-rw----+ 1 root root 238, 2 Apr 23 10:13 hidraw2
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Wow. Nice catch James! You hit it out of the park with the latest one... Actually got the Paranormal sn JAFAXXXXXXX to connect on the B550. It does not work on the X470 but I honestly no longer care about that since I can connect with the other machine. Test2.txt
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Vapeboy 3000 Replay - The unit that crashes I had modded the lock screen wallpaper but made no other changes as far as I can remember. On to testing!
	  Linux EScribe Suite Beta ThreadAmadVaper replied to James's topic in EScribe, Software and Firmware Installed the new version (Ver. SetupEScribe2_2022-04-26_INT_test.run) on the B550 machine. Did see something new but the results are still the same in that it crashed trying to connect and download. I attached the terminal output. Happy to report that this version also works on the X470 machine without crashing except for the Paranormal sn JAFAXXXXXXX newVersion.txt
