MetalVape90
Everything posted by MetalVape90
  1. Version 1.0.0
    137 downloads
    Took my Basic Additional Information theme and addded Kurumi Tokisaki from Date A Live on the first screen.
  2. Version 1.0.0
    282 downloads
    This is a bare bones theme that has been tweaked to display additional information: Voltage display for atomisers. Amp display for atomisers. Puff counter. With this blank theme you can freely add your own picture to it.
  3. I’ll check them out, but since I’m in the UK my fellow apes from the Planet of the Vapes Forum have said to try https://www.stealthvape.co.uk/ since their in the mod making department. I’ll have a surf round.
  4. Hey does anybody know which USB charging/data transfer chip I need for a DNA40 board? Just a while back I managed to get a VaporShark rDNA40 from the Planet of the Vapes forum, still works but it’s showing signs of ageing. The USB has seen heavy use and has fallen apart, the wireless charging feature still works and I there might be a grounding fault in the mod cause it doesn’t read the correct resistance of the atomiser. It’s a restoration project, trying to save the mod and bring it back to its former glory, that includes a new rubberised paint job. I was planning of putting a DNA60 in but I want to try and keep it original like it was out of the factory. Any advice will help with this.
    Better than my first attempt at making a theme. I made an Esdeath one.
  5. Version 1.0.0
    202 downloads
    If you've got a Wismec Reuleaux DNA200 or DNA250 this is the stock theme for it if you wish to re-install it back on to your old device.
  6. Version 1.0.0
    620 downloads
    Just like the Skynet T-800 theme from the Terminator, this is a Resident Evil theme based on the Red Queen. This theme at the moment is under its prototype stages, so there will be updates and improvements in the future. V1.0.0
  7. Version 1.0.0
    164 downloads
    The stock theme for the Asmodus Oni DNA250 Just in case you have an Oni mod and want to install the stock firmware back on to the device I've provided it here.
  8. Спасибо, пришлось перевести то, что ты сказал, потому что я не понимаю по-русски, но я буду продолжать тренироваться.
  9. Hi thanks for the welcome. Yea I’m experimenting with different contrasts between the theme and text/hub. There will be an update at some point in the future once I’ve figured out how to do things properly. It’s all practice at the moment. I got this Cyberdyne/Skynet theme on my Paranormal at the moment and it isn’t half bad. It does need improvement.
  10. Version 1.0.3
    163 downloads
    A basic Cyberdyne Systems/Skynet DNA-C theme. I tried to create a T-800 HUB display you find the old T-1 and T-2 movies for the DNA. It still needs quite a bit of work so this is just a basic Skynet theme. I'm still learning how to use the theme designer so once I get the hang of using the software to make custom themes this theme will have a V1.0.1 update. Version 1.0.2: Labelled under Cyberdyne/Skynet Theme Version 1.0.3: Labelled under Skynet 2.
  11. Version 1.0.1
    200 downloads
    A basic Carbon Fibre DNA-C theme featuring a voltage-atomizer display and a hit count. The colour coordination is off so I'll do an update for it later.
  12. Version 1.0.0
    341 downloads
    Just incase you want to have the stock Lost Vape Therion DNA75 theme back on to your Lost Vape Therion. Got the Flawless Tugboat stock theme uploaded here on just incase you have a Tuboat DNA75 and want the stock theme back on your device.
  13. Version 1.0.0
    116 downloads
    Stock theme for the Tugboat DNA75.
  14. Version 1.0.1
    105 downloads
    I've used the Stock Evolv DNA-C theme and made a few minor changes to it like changing the size of the font and adding colour, adding a hit count, voltage display, moved some of the display around and uploaded my own theme in the background. This is my first attempt at making a personalised DNA-C theme and it does need tweaking quite a lot. Feel free to download it and make a few changes. Current Version: V 1.0.0 Notes for upcoming V 1.0.1: Minor colour changes to menu. New images will be available. Evolv's logo removed from lock screen. Project theme No.2: Sabaton theme. (Prototype Theme!)
