jinx'd
Everything posted by jinx'd
what does each of the do ? thanx
thanx Device Monitor = diagnostics = advanced = update clock = does nothing.
what would cause this ? it also has the date error, probably related.
i wish it wasn't such a pita, but that is par for me. i wonder why i had to tweek the contacts. but its working, just used it, so that is all that matters. well, and that it keeps working and doesn't get damaged again.
its done and working well. i had to tweek the terminals. Thanx for the help, Wayne 👍
ok. but i see no way to get inside the zif to touch with a q-tip. the ribon goes all the way, but does feel loose, i can move the screen side to side with the connection being the hinge point. the clamp does not clamp it tight, but i can not pull it out. i press on the zif a little and that does nothing.
idk how i would clean the zif, other than spraying it with something. saying that, the chip doesn't have any juice on it. it was all on the inside of the mounting housing that holds the screen. old ribbon is dry also. so, how would i clean those ?
the one pic i saw, the ribbon was folded over the terminal, then back to the folded screen. am i missing something
ok. when i installed the first screen = all white display. i tried my other 2 screens, same thing. so i went back to the first screen and fiddled with it and got it working. now, trying to fold the ribbon in place = white screen. any ideas ?
its all good man, do your thing.
well that ribbon gets all bent up, i hope its robust. seems fragile to me
ok, i will go look ffor that. thanx
ok. i just watched the vid again, no sound. it sure does look like no wires, but, it really is hard to tell. no big deal, i was just wndering
ENGLISH. otherwise itss spam.
i just stated to install a new screen in a LV Drone. the ribbon is way to long. i am guessing they made them universal. so, how do i shorten it ? thanx
thanx 🙂
thanx. i will report back later with the results. oh, another thing have you ever heard of someone putting some type of screen protector film on the screens ? i bought some for this purpose, but have never tried it. the film for phones.
i was watching DsJlb(sp?) doing a review on the dna chips. he was powering a C chip with no wiring attached. i try to do this and it doesn't work. maybe i need a different cord ? i would like to test my new screen before putting batteries in it. and/or to trouble shoot a bad mod in the future.
Thanx. i was trying to lift the wrong part. while we are here, let me ask. the screen, it was stuck to its mounting panel, idk if it will restick the new one. is there something i should put on there, or just leave it, or what ? Thanx oh, is there a good way to remove juice from all the nooks and crannies ?
hello. i just got in my new screen for my Drone. i am trying to release the clamp for the ribbon, but its not coming loose, and i don't want to break anything. please advice, a vid would be great. i searched and didn't find anything. Thanx
ok, thanx Bill. looks like i will be placing an order
ok. but does it get in every screen the same way ? = that perfectly oblong splotch. seems odd to me, but what do i know.
thanx. that is exactly what mine looks like. but offers no solution other than arbitrarily replacing the screen, which is probably what it is. but, the little use i have on mine leads me to believe there is a defect in these screens. and/or there is some other problem. as you know, the Drones are prone to leaking, and mine did. as soon as it started to leak i immediately stopped sqounking it and cleaned. then i sparingly used it as a regular mod, which was ok with me. after very little use it was then turned into an ohm checker on new coils. on one of the coil checks i noticed this blotch.
