Vapors Tongue
Vapors Tongue last won the day on June 28 2024
Vapors Tongue had the most liked content!
About Vapors Tongue
  • Birthday 03/04/1970
  • Full Name
    Paul
    Downsouth
    HOG DNA 400C , Hadron Pro DNA
Vapors Tongue's Achievements
Senior Member
Senior Member (3/3)
55
  1. i don't think this is normal but after i loaded the new firmware it fixed the missing battery percentage and my personal fire picture that went missing on the other firmware. but i still don't get the time on the lock-screen. plus everytime i try to upload a theme or reapply the theme it doesn't get halfway until it goes back to the main firring screen , like it doesn't load completely. but it doesn't autollock now
  2. when i applied this service pack i lost battery percentage off my main screen and the imagine to display used for firing and the time still doesn't show up in my lock screen
  3. i have two DNA60C Stubby 21's. now the black one is on the latest firmware and i've had to revert the other one to the previous firmware because if i update to the latest firmware it auto locks even if i select it not to auto lock in Escribe. the other device is completely fine on the latest firmware. also both stubby's don't show the time on the lock screen even when i add it via the theme builder.
  4. Version 1.0.0
    244 downloads
    Ported this theme from my DNA250C which is somewhere on the forum. if you notice any bugs or broken menu's let me know. you may have to alter your escribe profile names in order to fit the status bar which in cooperates the profile
  5. I'm thinking of buying the new batch of Hussar Lore with the DNA60C chip but it says no usb port on the description. so how do you connect it to escribe if that's the case. ive watched a few reviews and none mention escribe at all and the regular DNA60 version doesn't mention escribe. by looking at the non DNA and the colour DNA body types don't seem to have a port on them. so do you think that you need to dismantle it every time you want to update setting via escribe or is there no usb port at all on the board its self. thanks
  6. well , i bought another 80C to rule out if i had a faulty pin and 2 new RBA'S and my custom threaded drip tips work no problems. as soon as i reverted back to the RBA'S i had originally same problems i had returned. so if you cant get replay to work with an RBA try a flushnut for a better connection.
  7. if anyone reads this in the future the solution is simple but rather annoying , you have to use a flush nut to get that much downforce to make replay work . drip tips of the screw in kind wont work or be 100% what the pin needs for contact between the boro tank and device.
  8. UPDATE ! . i had a brain fart and i completely forgot the SAN AIO came with the stock coil option shift boro tank and im pleased to say REPLAY is working just fine. so thank god its not the mod i don't need to RMA it and we can now say the Voltrove RBA and the Meson RBA do not work with replay on the DNA80C. Happy days now !!!
  9. only way to check my RBA''s i do have is to buy another and hope im not that unlucky to have bought 2 devices randomly with the same fault .. lol. so if the new one acts the same it must be the RBA and not the device
  10. unfortunately not I'm having a clear out and I've sold any other RBA i did have. but I've a billet box and in the DNA60 they both work in temp mode and the same coils work with replay in my 250C. this is happening on the SAN AIO DNA80C
  11. top screen replay not set , bottom screen replay set . nothing but fresh air and the atomizer error message
  12. i set it to 5 probably experimenting , i think its set at 1 as standard as the advice on allowing compatibility with allow on unlikely coils
  13. i can only see live ohms when replay isn't set. as soon as set reply after the first puff , the live ohm's show but briefly disappears as it says check atomizer so unable to capture
  14. also a pic of the atomizer analyzer
  15. followed your instructions and here are the results. the rba is a voltrove , it also happed in the stream crave meson boro tank . same results
