Kurtis_Loew
Kurtis_Loew's Achievements
  1. It may be a poor connection in the mod's 510 connection, as well. One of my Lost Vape Mirage DNA 75C devices works flawlessly, with no irregular messages asking about the new or old coil, while a second Mirage DNA75C still asks me about the coil, even if I use the exact same tank or RDA/RTA. Several of my RDA/RTAs and one of my sub-tanks have an adjustable 510 at the base, and they're making good contact, so I can only assume that it's a problem with the mod itself.
  2. What is the purpose of "Current Profile" in EScribe for the DNA75 Color? I don't recall seeing it for other DNA devices. Is it necessary, and if so, what is it's purpose? With my other DNA devices, it doesn't ask for a current profile and I just change the settings for each of the profiles, regardless of the profile the mod is currently in. It seems to be redundant, and I don't know if I should change it, or simply ignore it and adjust all profiles regardless of what profile my mod is currently in. Thank you!
  3. @James Thank you for the info! I'll check it out after work.
  4. @JamesI can't find SP27 on eScribe, as others have stated.
  5. @mackman Mine does it with A1 Kanthal, SS316L and all sub-ohm tanks. I turned on the Autolock feature which was set at 60 minutes. It would then lock after an hour of no use, and I'd have to press the fire button 5 times to restart it, but the device stopped asking about the new coil. I then turned the Autolock feature back off and the device isn't asking about the coil as often as it was before. I only bring this up as it may help Evolv rectify the issue.
  6. I don't use temp control. It happens on only one of my two DNA75C boxes. Otherwise, I love this chip!
  7. Where do you get SP27? It doesn't show up on eScribe on my Mac, or PC. It only goes up to SP25...
  8. This is happening to one of my Mirage DNA75C devices, as well. Thought perhaps it was the fault of the RDA I was using (Drop), but it happens with every RDA, RTA, and SubOhm tank I attach, even with an adjustable 510, I still have the issue. I also see in this thread that there's a service pack 27, but it doesn't show up on Escribe. It only goes up to SP25. What am I doing wrong? I've been a long time user of DNA200, 250, 166, 133 but never a DNA75C. It's a great device, but a bit annoying when I go to take a pull and nothing happens, only to see the message about a new or old coil.
