Jadegrsx
Everything posted by Jadegrsx
  1. I ran the anaylzer test using the open loop wire method, I'll let you know if it fixed it Edit: after running the anaylzer my mod no longer says check batt at 60% yay
  2. I ran the anaylzer test using the open loop wire method, I'll let you know if it fixed it
  3. Bump with 67 views
  4. Nobody?!
  5. Battery analyzer*
  6. And now check battery again at 42%, what do I need to do? I don’t have the materials unfortunately to do atomizer test
  7. Hey guys, so I have brand new vtc5s, downloaded someone’s vtc5 profile, and on my Therion166 I am getting check battery at 62%. Used to be more like 15, which even then I was baffled by edit: just turned down the boost to 4 from 11, and Its firing fine, but need the boost for these big triple Clapton’s in the tfv12 rba t.
  8. How do I know if I have the 5a's?
  9. And you can set up da BOOST mane!
  10. I just fired mine in escribe and it was 7.2 fire output...
  11. Batteries are LG 3000 3.7v Device monitor says 7.2ish volts when firing
  12. Cool, I'm a newb to all this, so just fire it when plugged into escribe in the monitor and see what the voltage output is?
  13. I downloaded sp12 with the boost for my therion166, set the boost all the way up, and I still notice no difference? Just running the tfv12 huge ass coils
  14. Does this still work for DNA250? I tried to do it on my therion166, and seemed to let me set it up in escribe, yet there was no change with the slight delay to fire, with preheat 25 watts higher, and punch 11
