iambyrdman
iambyrdman last won the day on March 9 2020
iambyrdman had the most liked content!
  • Full Name
    Winston Byrd
    Wadsworth, OH (Cleveland area)
    DNA200 DNA75C Want DNA250C
iambyrdman's Achievements
Senior Member
Senior Member (3/3)
13
  1. So, I printed the first sled. Super easy print. Took about 3 hours.
  2. I agree with most, if not everything. Perspective is everything. I really do try to use a different one every day. I have 2 Paranormal 250Cs to add to the mix to make 10. I had a set of 6 USBs that I lost, for some reason, don't even remember how now.... They don't all stay charged all the time, not by a long shot. And I use them for other stuff too. At my bar I hang out at all day... Most have built in 21700 pairs without sleds, permanent like. I have a 3D printer now, I should just print some sleds how I want them! Thanks for all you wise insight and wisdom! You are awesome, smart too... Bought this for now, easy... https://smile.amazon.com/AmazonBasics-60W-6-Port-Wall-Charger/dp/B0773K737F
  3. I only used the computer for 1 to see if it was connecting. I built a 100 watt 5 volt box for this and other projects.
  4. I'm using a 5 volt 20 Amp block I built and I didn't pug all 8 in at 1 time to test. I just plugged 1 into a widows machine to see it would chime when I plugged it in to tell me a connection is being made. As I said, it was but not charging, why? Is that ok? 100 Watt charge block? 5 Volts at 2 Amps (10 watts) each when charging, right? Thank you for your wisdom, I understand. But anyway.... Back to the original question. Does the DNA board need more than the red and black wire in a usb cord to charge? Yes or no is a good start...
  5. Anyone see a new place pop up selling DNA260C enclosures? I miss the Curve!
  6. I have 8 DNA 250C Setups and want to keep them all charged. So I took 8 USB cables and spliced the Red and Black wires. When I plug one into a Windows Machine it tells me something is connected but they do not charge. Does the DNA board need 1 or more of the data lines? I'd sell most any if you want one! I don't need 8!!!
  7. I don't know why I thought you could build a 100 Watt device that way. Thanks for the insight.
  8. I just noticed escribe doesn't have a 1 battery option.... How do I do that?
  9. You pay attention well! Officially, I own 3 businesses in the state of Ohio and have Art hung in 3 States. I stay busy, makes me feel important or something. I ned to find someone with a CNC machine is all. I would love to build one with mounting posts mounted to the inside for no screws on the outside or epoxy in.
  10. Nothing? I might need to start a business...
  11. Bottom line, does not replay. Kind of strange how the single (but not double) will give a 'Save' while in replay. But does not seem to work with a Nickel coil setting. So I figured SMOK did like others and used something else for the leads. So I took one apart and cut off the leads to use the mesh in a mesh RDA. But replay does Not give a 'Save'. Go figure... Ohms turned out being 0.163.
  12. A refresh and getting back on topic. Is there anyone other than Analog Box Mods selling enclosures now? Drip3D went away a while ago
  13. and as you can see, it's not charging either
  14. I've built a 2 Cell device and bridged the last 3 pins on the balance leads. But I still have a 3rd cell show up in device monitor. The 3rd cell shows up with almost No voltage. Why?
  15. So it will only pre heat with 100 watts? Not continuous? Again, not that it matters because I still can't get it apart....
