AntoVape
Everything posted by AntoVape
  1. @dwcraig1 First of all thank you for replying and I would also like to ask you one more question. Has this value some effect in terms of vaping or it's simply a value to adjust to read ohms correctly?
  2. Hi, I bought this mod and I noticed that the mod resistance is set to 0. Has anyone bought this mod? I hope someone can tell me what value should I put to get an accurate ohm reading. I usually use Kanthal coils, but this mod reads 1.17-18 ohm instead of 1.09-10 ohm. It's a dot platform so it doesn't use Boro Tanks and I don't know how I could measure the internal resistance...
  3. I agree, but if it reads a lower voltage, the discharge will be faster even if the difference is minimal...
  4. I don't know why, but I think that the Wh that was put in the csv file is not exact...
  5. The situation improved when I uploaded the new profile, because with the default curve it reads a lower percentage...
  6. @mactavishI use a NiteCore D2. I've tried with 3 different VTC6, but I've obtained the same results, so I guess I didn't get the right curve or maybe is the mod itself. Is it possibile that a wrong voltage reading is caused by a wrong csv file? Surely it can affect the percentage reading, but I'm not sure it can do the same with the voltage.
  7. I uploaded a profile for a single VTC6 with 10.42Wh. My charger reads 4.20v while Escribe reads 4,16v if I'm not wrong. What could it be?
  8. I bought it. The mod is perfect, but I noticed that it reads my full charged battery at 4,13v instead of 4.20v and I'm using a VTC6 battery. I'm wondering if the adapter makes reading inaccurate, thus can you tell me if it happens with 21700 batteries?@tramog @Jasonvillamil
  9. @tramog @Jasonvillamil Thank you very much! I'll buy it!
  10. Hi guys! I'd like to buy the new Mirage 75C, but I'm scared due to my negative esperience with Paranormal line by Lost Vape. I'd like to know if there's any issue with the mod internal resistance or issues related to construction. I hope they did a good job this time.
  11. I'll solder it and I'll check it later.
  12. @TheSwainIt depends. I use Kanthal A1, the smallest difference is about 0,005 and the biggest about 0,1. I tried with 5 different atomizers. Should I check the soldering? How could I remove the black isolator disc?
  13. @TheSwainI did it on my Paranormal DNA 166 and it works. I solved my problem with fluctuating ohms and improved ohms reading, but there's still a difference compared to my other mods. I cleaned the 510 with hot water...could it be the problem? Should I use alcohol or acetone? Thanks in advance.
  14. Thanks to you, I can say I solved the problem. Ohms don't fluctuate anymore and the difference with other mods is about 0,01 now. Do you know what is the correct internal resistance for this mod? I've found that on Escribe it is 0,01.
  15. Hi guys! I'm here because I've got a doubt. A few days ago, I received a Paranormal DNA 166 and I noticed that It reads different ohms compared to my other mods (both Eleaf) and this difference is always about 0,03 ohms. I was also wondering if it's normal that the coil changes its value when I press the fire button for the very first time. After that, it doesn't change anymore. I use Kanthal in Power mode. Thanks.
