Moe
Everything posted by Moe
  1. Thank you, it doesn't work
  2. Hello, I have Lost Vape Triade 250, its running with 3 batteries., I want to make it work with 2 batteries, I tried using Escrib but when I press fire it shows Shorted !!! any Idea?
  3. I'm using dual SS 316 flat Clapton wire one Gone RDA, I would like to run the temperature control, but I'm not sure about my settings. I need your advice to select the right settings for that. Now, whenever I enable the TC and try to fire it stops and show me OFF.
  4. regarding the 2nd point kindly find the below video, which shows that it can run with 2 batteries up to 167 Watt how do I configure the batteries to get accurate 'battery icon'? is it possible to remove the batteries icon from the screen?
  5. I have Triade 250 from Lost Vape. I'm using an external charger (Nitecore D4) to charge all batteries. I have some questions in this regards: 1- do I have to turn off the Mod before removing the batteries? 2- Is it possible to run the Mod with 2 batteries only? 3-I'm using 3 sony 2500 mAh and another 3 AWT 3500 mAh as a backup, Is this fine? (I don't mix theme)
