MikeTheDude
MikeTheDude's Achievements
  1. Which coil are you using? The .5 ohm head @ 80 watts needs 6.32 volts for the pre-heat @ 100 watts 7.07 volts. I can only the the tank with the .5 ohm head on the DNA 250 which has a 9 volt limit. The other mods I own (DNA 75's) have a 6 volt limit so I have to use the .25 ohm head to get a nice vape.
  2. No problem Bud. I guess it is the size of the coil and/or the material used. I have a Kanger Toptank with a twisted 28g Ni200 .04ohm build in it and keep the temperature at 415f. I just set a profile up for each tank/rda according to what vapes best. Seems the setting can vary from each device.
  3. Hello, I have the Crown 3 on top of a DNA 250 device using it in TC mode. I attached the profile and csv for the coil to this post. If you do not want to load the csv use SS 316 as the material. Settings on device are: 80w, 515f, 100w preheat power. Crown 3.ecigprofile uwell crown ss.csv
  4. I just downloaded and installed the latest version of escribe from the website. The functions you listed are still there. Hope this helps!
  5. Version 1.0.0
    1,768 downloads
    Simple Evolv DNA 250 theme
  6. Phoenix Immortal DNA 250 Custom
