iandvaypes
Everything posted by iandvaypes
feature request: scrolling stats
iandvaypes replied to iandvaypes's topic in EScribe, Software and Firmware
Also, being able to have scrolling stats while off of the charger too. -
Crickets....... -
When I'm out and about I would like to see more stats than just the three that we can select. I was wondering if it is at all possible to have the three scroll to another set of stats, either automatically or manually. Better yet, smaller wattage numbers with stats below the wattage setting. I'm sure that this is debatable as others prefer it to be different. But I'm sure that a lot of folks would like to see more than three stats while out and about. -
dna200 inside a vaporshark vaporflask? I think so.
iandvaypes replied to iandvaypes's topic in Installation and Assembly
This was an extremely difficult build. From extending the screen ribbon, removing the on board usb, soldering an extension micro usb, fitting the dna 200 in the plastic sled, isolating the positive and negative contacts on batteries, fitting extra large wiring, modifying the up down button board to getting it all to fit. These batteries are removable. I used a combination of kapton tape and copper tape for one side. -
Zif socket and cable
iandvaypes replied to Alexander Mundy's topic in Connectors, Components, and Accessories
It's a work in progress. Having to extend the usb and screen cables. -
I wish. The vs vf charging board is about two inches long and the dna200 won't fit. Two boards actually. I just cut it to size to just use the socket and extend the dna200s micro usb. The board fits in the slots perfectly and won't wiggle wobble which is why I salvaged it. -
Still on the 7/29 r1. It just started it this morning
I just used the micro usb port from the shark flask. I know that it will fit the shark flask so I'm going to stick with it. I had to trim it down a bit to fit the dna200. It works and still connects to escribe -
May be slightly off topic, this is how I extended my usb. You might think I'm crazy but it works great. Hooked up to escribe and it allowed me to upload a custom screen for "check atomizer." I used the pins of a micro usb plug that I tore apart. And to stay on topic, you can see in the pic how I used heat shrink for the ribbon joint on the screen. I cut up two small pieces of an old gift card and sandwiched the joint. Then I surrounded the joint with heat shrink. Protection with a nice clean look. -
I was also about to say modcrate. Less than $5, you've got to to crazy not to buy a bunch of screens. I bought 5 for myself. Never can have too many. -
I think that I'm going to carry a spare mod with me today, just in case.
It is an evolv error screen. This happened on my evolv beta mod. I woke up this morning, unplugged my device as usual, tried to take a vape (yes I vape first thing in the morning while still in bed), then I got no vape, checked the screen and nothing, then I saw the error message but at only 5% brightness. As I try and squint to see what was going on, boom full brightness. This was rather disturbingly bright before my eyes could adjust. "ERROR PRESS UP TO CONTINUE." What do I do? I press up. It's vaping like normal. Except my mod is fully charged and all cells are at 4.2 volts. Personally, if I were to guess, it was protecting the cells from overcharging. I'm not sure though, I'm not evolv. Only someone in evolv can explain this. I did check the manual and according to the manual, no such error message exists. Yet the error does exist. I'll post a pic if it happens again.
I just had this same message this morning. I checked the manual to see what it is but I can't find anything. Weird.
OK. Now you're going to have to post close ups. I failed on one. Good thing I bought extras. -
It's worth a shot. To eliminate the problems, I would first start with the easy stuff before resoldering what looks like a headache. -
Have you tried to flip the wire in the zif socket? -
I unscrewed the board and messed with the screen. It stays at about 10% dim until it stoped working. I vaped it all day yesterday with the screen omitted and it worked great. I brought my laptop and used escribe as the screen when needed. I have ordered 5 extra screens for the just in case moments. I probably won't need them now that I know what to look for.
Any updates to this? -
Great idea. Thanks!
The beta mod that was sent to me has the dreaded pinched screen. I noticed that the display would dim every time I fire the atomizer. It was no big deal to me as it kept on ticking. Now it's rebooting the device while I'm firing the atty. This will reset my resistance to the now hot coil which everyone knows that this will give off undesirable results. So I'm going to order some extra screens in the future and replace the one on this mod but I'm going to place the ribbon AWAY from the firing button. My question is: Does the pinched screen ribbon cause a reboot? Or is there another problem I need to trace down? I'm hoping it's the ribbon as this is an easy fix. Note: I did update the firmware to the 7-29-15 R in hopes to fix this. It's not working.
I sent John a PM, but I haven't heard anything back yet. Not quite sure what to do with this dud of a chip. I haven't really got to experience the dna 200 yet. :-(.
I use a normal 1 amp samsung phone charger. That cable worked great for escribe also. I also used my two laptop usb ports. The port with the lightning bolt symbol is the one that made it really hot and smell like it's burning. It started doing this after the chip went out. I do remember that it got very hot by that three port component and burned my finger.
