steefmobiel5
  • Full Name
    stephan buijs
    netherlands
    hcigar vt200
steefmobiel5's Achievements
  1. Hi there, another question/suggestion from me. Eventhough on the 75c a buttonlock isn't really necessary, due to the use of the select button. It would still be nice if that option could be added, i sometimes want my settings to be completely safe when i put it in my pocket for min, but not having to lock it. When out and about having a buttonlock would be nice, so i don't have unlock everytime i take out the device to vape. greetz stephan ps yes i have had movement in the pocket causing changed settings on the 75c a couple of times. Luckily nothing serious, so for now i will lock the device when pocketed. Also it seems i can fire from every screen except lockscreen, no matter whether i set fire from this screen or not.
  2. Version 0.0.4b
    42 downloads
    hello everyone, i have build this theme for the dna 75c. This is a basic version of the bentesselbig theme, with minimal settings possibilities. Here it is with just the basics. I'm trying to improve readability by using status bar, which i hope will work. That way i can minimize screen usage, so i can add more settings in the full theme. The new update uses a different approach for readability, no more statusbar. Using conditions and free movement. Also using icons to save screenspace. I have added some theme toggles and gauges. Also i have introduced some color coordination for the menu. Purple is menu layout.(Highlighted yellow) Dark pink for settings screens.(Highlighted blue) Green for info. White for adjusting.(Highlighted red) As always feel free to comment or ask questions. Actually please comment on which version is working better(003b or 004b), i will try to update and add more options. Want to use this as a base, just mention where it came from. greetz stephan
  3. Version 0.0.3b
    60 downloads
    hello everyone, i have build this theme for the dna 75c. Still i would like to throw this out there for people to try or mess with. This is a basic version of the bentessel theme, with minimal settings possibilities. Here it is with just the basics. I have added some theme toggles and gauges. Also i have introduced some color coordination for the menu. Purple is menu layout.(yellow highlighted) Dark pink for settings screens.(blue highlighted) Green for info. White for adjusting.(red highlighted) As always feel free to comment or ask questions. Want to use this as a base, just mention where it came from. greetz stephan
  4. Hi there, Would it be possible to add more font choices. For now we can set 3 sizes small,normal and big. But i would be able to make a better looking and usable theme if there would be 5 choices. Xs, s, m, l, xl. Just so you can make everything fit nicely. Yes, i know you can set the size for each, but i really like to use 4 or 5 different sizes in my theme. Greetings stephan ps. i already tried using pictures with different textsizes, but the memory fills up in notime.
  5. Version 0.0.5b
    59 downloads
    hello everyone, i have build this theme for the dna 75c. Still i would like to throw this out there for people to try or mess with. This is the big letter version of BenTesseL for those people who like to operate their device without magnifying glass. Full settings, but leaving out info(might get around to adding more in next update) All custom icons, toggles and gauges. As always, feel free to use this theme and comment on it. If you like to use it as a base for your own theme, just mention the base. how to use: - green is info(light blue or yellow if updatable) - white is adjustable(red highlighted) - dark pink to other screen(blue highlighted) - purple is menu layout(yellow highlighted) greetz stephan
  6. steefmobiel5
    vt75d
    hi mecoreis, your device is rebooting. You should contact the shop you bought it from. Perhaps one of the connections to 510 or battery are faulty. A screen disconnect would not trigger a reboot. It would just go back to screen and you should still be able to vape during screen off. Best case scenario would be a theming mistake, so you could try loading another theme first. sorry to say so, stephan
  7. Version 0.0.4b
    79 downloads
    hello everyone, i have build this theme for the dna 75c. Theme is meant for new users as well as advanced users. This you can see in usage as you only need the lock, main and new atomizer screens to work the device. These 3 screens will give you all options needed to vape, however 20 more screens are available for those that like to dig in to the settings. How to use: - purple is menu layout(yellow highlight) - dark pink takes you to screens(dark blue highlight) - green is info(light blue for updates( yellow for some screens)) - white is for adjusting(red highlighted) Copying this theme. Feel free to do so. Just mention you stole it from me. Comments and suggestions. Please feel free to do so, i will consider adjusting and fixing theme per suggestion.
  8. Thank you wayneo for pointing out that tip. Completely forgot about that one. Btw mine isnt mint anymore after dropping it a couple of times at work(11m drop and hitting every rail in between that and the ground), but still going working flawlessly.
  9. Hi chrismel, That definitly looks like your screencable is lodged under the firebutton. Replacing the screen and tidiying up the cable will probably solve your problem. I had the same issue with my smy sdna 75. It was quickly resolved with a new screen from evolv for $18 shipped, which arrived here(the netherlands) in 4 days from the us after ordering. Replacing the screen took maybe 15 min. Including the adding of padding between button and cable, so the sreencable doesnt get cinched. Greetz stephan Ps. Open up the mod first to check the cable is actually inserted on the board correctly before ordering.
  10. Top is profile name bottom is wire name. So giving profiles more generic names like preset 1, would make a less confusing screen when you change wire type for a given profile. Also loading a custom screen will get rid of double names, but you would have to remember which wire type you chose if you change wire type for that profile.
  11. Thank you evolv. This update is awesome. I however did not encounter any problems downloading settings from my device in the new software suite. Also a +1 on an adjustable tcr profile. Being able to change wire for profiles was an unexpected bonus, but having the ability to load a wire with adjustable tcr would be the bomb. And that would leave me wanting nothing more.
