macz
macz's Achievements
Senior Member
Senior Member (3/3)
  1. Hi there, what do you mean by setup? Are you trying to run in tc mode? Tc doesn't work with kanthal, try get other wire i.e nickel, ss.
  2. To do a reset/rollback go to Tools > Update Firmware to force an update. If you've had escribe installed for awhile all versions of the firmware should be stored locally in the following location: C:\Users\UserName\AppData\Roaming\Evolv\EScribe\Firmware\DNA 200
  3. Different 1300mah have different settings, it is best you run battery analyzer to get the correct Wh (Mod tab section).
  4. Here try this website : http://dna200.de/kurven_akku/
  5. What mod are you running on for those batteries?
  6. Did you try locking power by holding up+down button?
  7. Firmware updates is for the board (dna200) that Lavabox are using
  8. @ChuckyButt200 Edit: Try change resolution? Maybe that will work?
  9. yes, 2016-02-10 mine doesn't say hold to change power. however, after the message 'hold to change temp' it does let me adjust the watts where i would normally adj my temp.[/QUOTE] Yeah I got the same "Hold to change temp"
  10. Devices that claimed able to do 200w with 2x 18650s actually firing at max between 150w-160w.
  11. macz
    Broke down
    Blown if fuse turned to white
  12. This store is in Singapore http://www.gorcshop.com/collections/connectors/products/grs-xt Get the xt30 ones
  13. You can get it from here https://modcrate.myshopify.com/collections/dna-200-enclosures/products/silo-950-kit
