OK I fixed the problem. I changed batteries because the ones in the mod were dead but still firing hence my battery bar was empty and the % was 0. DOH!
Yeah I did remove the batteries for 5 mins or so. The old turn it off and turn it back off again trick was my last resort. No battery settings were changed in the process.
Hello, I have just updated the firmware to 1_2_SP3.sw-service. on 5 DNA Mods. I have an Issue with one of them. I can not get my battery meter back on the HCigar VT133, this is strange as I have 2 VT133's and one has it and the other doesn't. Psyclone Evo - No Problem Triade - No Problem Reuleaux - No Problem VT133 - No Problem - Board Programmed 25 March 2016 02:22am VT133 - ** No Battery Meter - Board programmed 24 Feb 2016 03:44am** I have rolled back the firmware to version 2016-02-23 and tried 2016-02-10 with the same results, still no battery meter after soft reboot. All my mods are set up exactly the same with the same wire profiles, profile screens etc. I have also "reset to default" and re-loaded my saved profile for the VT133 and still no battery meter. I have tried soft and hard reboot multiple times and still no luck. The mod still works and SS is much much better now on all of them so thanks for that. BUT........I'd like my battery meter back on my VT133 please :-) Thanks in advance for advice.
Panzer settings from djlsbvapes.com Battery: Capacity: 15,85 Electrical: Mod Resistance: 0,025 Thermal: Case Cooling Time Constant: 460,91 Case Heating Time Constant: 203,11 Case USB Charge Temperature Rise: 11,75 14,12 Minimum Ambient Temperature: -20 Maximum Ambient Temperature: 110
