sotirisba1
  • Full Name
    SOTIRIOS BASTANIS
    GREECE
    DNA 200
sotirisba1's Achievements
  1. Ok, I did it. I just put everything back together and it works fine.
  2. I'm thinking of cleaning the board in isopropyl alcohol in an ultrasonic cleaner. I'll secure the IPA in a bag with the board to be safe. Will this be ok or the chip will die?
  3. You can use 4 batteries (2pairs of parallel in series) to maximize capacity with a maximum output of 133W
  4. 0.04 ohm dual or sinfle coil?
  5. Two 26g claptoned with 32g Ti grade1. 3mm inner diam. I pulse them at low watts in a dark room to check for hot spots and make them warm evenly. Once you make it work you get a grate vape
  6. Check these /topic/66226-topic/ /topic/67232-topic/?do=findComment&comment=905179
  7. Do you think I can't get hot enough vape with this fused clapton Ti coils? And it works perfect on tc.
  8. I pulse all my TI builds as ChunkyButt200 does. Never got a hot spot ever since. Great Vape. Defenitally my favorite TC wire. I bilds Ti claptons, I even built a stagged fused clapton, all TI and didn't have a problem.
