speed4mee
Everything posted by speed4mee
  1. Did you test your coil on another temp regulatet device, probably too low temperature at 350°F?
  2. I think this is a ModMakerBox 846024
  3. @vmax100uk Did you Change Mod - Battery - Capacity to your specified Wh? Use the Watt-Hour Calculator
  4. Then your USB Voltage is faulty. You can connect to EScribe so your USB Data Line is ok.
  5. Is there a lighning in the battery symbol? If not then try another USB cable On your screen USB Power is shown as 0.013W, that isn't normal
  6. Did you use USB 3.0? I'm using an external USB Charger with 1A. To see if it's loading change Screen - Charging Field 1 to USB Current. And don't forget to set the Charging Brightness to 80 % (default is 0).
  7. That would be nice I have that Live Ohm Reading on my SXK Zero Clone 60W on Temp Control.
  8. It's at the Field1 as Default. It shows me only the static value from the start but not the changing resistant value in Temp Control (Live).
  9. Thanks, but i mean Live Ohm Reading on the device. Under Screen - Fields - Default Field 1 there is only Ohms (Standard)
  10. Is Live Ohm Reading possible?
  11. Thanks, which model?
  12. Which enclosure is this? I've made a function mod, all is hand-crafted :
  13. You can download the file SetupES_2015-07-16.exe and then install in Windows. After that you can upgrade your firmware to Version 2015-07-16
  14. Is it also possible to disable the charging process while using EScribe?
  15. It would be nice if i can switch from Device Monitor to the Main Screen without closing the Device Monitor Window
