DrDitto
Everything posted by DrDitto
Hi James, Thanks form you fast response user is part of group but there is no files in /etc/udev/rules.d and also there is no /usr/bin/pkexec How can i fix this issue?
The main problem is the battery sled, is pain in the ass. ther is no space to use the recomended wire gauge. Let me figure out a solution as soon as i get i will post it
There is a lot of work, yes, the main problem is that original battery sled does not allow the use of propper gauge cables.
First First. The button does not work the fire switch requires that the button will be filled with epoxy or solder in my case Second the recomended wire gauge requires tweaks. Mi solderin skills are not the best, but no bidged solders. Battery sled requires hacks
I order a dna250 board from protovapor last thuesday, I live at Costa Rica. As soon as I get it, I wiil document the complete process: Disassembly510 changebattery tray wire changebalance tab wiringRe assembly
Board Incomming!! As soon as I get I will take the pictures of all process. Step by step
The main problem with rx 2/3 ismael the 510 And the small gauge cables. The only way to fix that crappy construction ismael relación the 510 Android use the proponer wires suggested bytes evolv
The rx2/3 screen has a diferent connector
Thanks a alot VapingBad for the feedback on this convertion
Whe user (me) jajajaj switch from the 2 battery backcover to the three ones, the blue line dissapper and the batery located at the otger cover, represented by the green lines takes part into the circuit and rise the voltage to 11.1v tara!!!! full 200/250w after changes the battery at escribe
The rx200s or rx2/3 will not work at all the conectors are so differents
the Other change than must be applied is to use proper gauge cables in order to avoid the loose of voltage/current that the actual ones induce in the circuit. This is the main reason why rx/3 has this poorly batery life.
Ok I figure out the connection using both configurations When the two battery cover is installed the cover represented blue the blue line acts as a jumper between tap 3-2 at the balancer connector when the tripple 18650 cover is installed it will use the releaux config. there is no blue jumper. Can anynbody please check this connections? The gnd is jumped to b- and the tap 3 jumped to b+
Ok at the moment I am makinfg the plans to swap the board. I will make a screen suppor in order to center the dna200 screen over the rx2/3 front panel
The initial question is related with this fact: How to wire the balance charger tabs as a normal way in 3 18650 since the conver acts like the la 1860? and setup the dna200 as 2s or 3s in escribe dependending on the cover I will use?
Let me try explain me in a technical matter. The two 18650 setup has two components a battetry tray with an open circuit and a cover with a jumper. The circuite closes when the bumper contacts the battery try. The tripple 18650 setup has two components a battetry tray with an open circuit and a cover with a battery with conection points. The circuite closes when the cover contacts touch the contacts the battery try. The reason to ask, was related with the way than the dna250 or dna200 can see the jumper. But the mod must to work yes or yes in a dual setup because the cover closes the circuit.
My question is related with this fake battery because the monitor could sense as unbalanced pack
Yes the 2 battery make a jumper like a fake battery. Point is, would i wire as a normal 3 cell config, and change the mod at scribe from 3 to 2?
Help to wire a dna200 into rx2/3 case ik order to can use both 2 and 3 cell configuration
