LarryLenz
Location
Henderson, NV
DNA200
LarryLenz's Achievements
BillW50, When I was going to purchase my hCigar VT200 DNA200 from ecig, I noticed that they had a disclaimer that read that the warrantee would be void because they were selling the mod below the manufacturers recommended price. So I didn't purchase my mod from them. So when you purchase something high dollar from ecig, be sure and read their disclaimers.
Hi. I have an Hcigar VT200 and it works perfectly with NI200 and Kanthal. But when I use SS 361L (UD makes it) it screws up in Temp control. For instance, I set it at 400Deg F and it works fine for a while. Then one time, when I pick it up to take a vape, it ramps up to 700 Deg F and burns the vape. I can move the atomizer to the Wismec Reuleaux RX200 and it works just fine in temp control. On the DNA200 I set one of the 8 spots to SS 316L using 0.001 as it will not let me use 0.0092, which I have set on my RX200 and my Evic VTC Mini. I have tried this in my Uwell crown, TFV4, TFV4 Mini, and the Griffin. The same thing happens on all these tanks. I also have an Evic VTC Mini and it works just fine on that mod as well. All my coils are around 6 to 8 wraps not touching, and I do not preheat them. Anyone have any idea as to what might be wrong? This has been an on going problem for ever. Only with SS316L 26 gauge wire. Thanks in advance I can post screen shots of when it works and when it fails, if that would help any of you.
510 99.9 pure copper Mod resistance tools
LarryLenz replied to vegabob's topic in Connectors, Components, and Accessories
Hey Bob, Got my unit today. Did the test and my hCigar VT200 Mod Resistance is: 0.004 It is what I had guessed at, but now I know for sure. It worked perfectly with no fluctuation at all. Thanks again Bob. Oh, your shipper correct my address so it was correct on the shipping label. Go figure -
If it were me, I'd do the following: 1. Wait for the new VS. or 2. Get the Wismec DNA 200 or 3. Give it 1 more shot and get the same manufacturing date VS. Talk to the store owner and ask for his opinion. He can tell you if the VS mod has had problems as well as the Wismec DNA 200. Let him help you make the decision with you. Just my thoughts
Johan, you have really good points. I didn't know that about him. I'm sure glad you responded with that info. I will watch him more closely from now on. If he isn't going to be honest, then he can't be trusted. Thanks again for letting me know this.
I think you can trust DJLsb Vapes. He seems to be a great reviewer and I've downloaded many things from him without any problems. I agree that the 0.022 is high. I would just recommend testing your device to insure you get the correct one for your mod. I wonder if he got that when he tested his VT200 or he got it straight from hCigar.
When in Device Monitor, No temp is showing.
LarryLenz replied to LarryLenz's topic in DNA 200 and 250
I will be checking my resistance when Bob's adapter arrives. I just purchased one to do the testing. Thank you all for you concern and help determining any issues I may be having. I'll let you all know once I do all the test and set the mod up properly. I think it is pretty sad that hCigar doesn't take the time to set up their mods before they ship them. That is a big negative in my book. Spirometry. You just might be right. It all looked correct on the mod display. mactavish. When my mod reaches the temp I set it at, it starts to stop firing. But this doesn't happen every time. If it is flashing"Temp Protect", sometime it won't even fire when I hit the fire button. I have to do the final tests and set the mod correctly to be sure. So until then, I will just fight my way through dc601. When i changed the watts to 30, the temp does go up, but the vapor is to harsh for me. So I lowered the temp from 350F to 300F. Save vape, and it never give me the "Temp Protect" message. -
HugeEgo, I am vaping at 350F but it only goes to 250F. On my 3rd juice fill on this coil and it goes up to around 280F. I'm using the RBA section with an NI200 28 guage 6 wrap coil I made. You can give me all your technical reason why I shouldn't be getting any vapor, but I'm getting great vapor. My juice is 60%VG - 40%PG. It is a very stable coil and never sets off the Temp warning on my mod. I made this post to get assistance on my Escribe software, not for you to tell me I'm not getting any vapor. I'm getting lots of nice cool vapor, just like I like it. I'm not going to take a video and post it of the vapor production I'm getting just for YOU. Please just drop it. -
HugeEgo, it is a very cool vape with tons of vapor. That is what I like. I can't stand hot vapes. And it says Fahrenheit on the screenshot, so Yeah... Fahrenheit lol nismith8 , it's all good. Thanks for trying anyway I do appreciate all the help. And the Uwell Crown with NI200 is my favorite tank. Ordered some SS 316L to try. I'm hoping that will be even better. -
Thanks nismith8 . I'll give it a shot. OK set the temp in Device Monitor to 600 deg F, took two hits and set it back to 350 deg F and still no Actual temp while vaping. Hmmmmm ******************** UPDATE: ******************** I set up a profile for the Kanger SubTank Mini, uploaded it to my mod, and selected this profile. Ran the test again and it worked. Go figure. All the setting were the exact same. It is Working Perfectly NOW lol See Screenshot. -
Hi. As the screenshot shows, I take 2 hits of my hCigar VT200 running a Kanger SubTank Mini with a 0.21 ohm NI200 coil. The mods works great with this tank, but when I check it out with Device Monitor I get no temp readings while firing. I've tried 3 other tanks with the same results. Any ideas why this is happening to me? thank you in advance. -
Temp Control doesn't seem to work correctly.
Thanks VapingBad. I replace the coil and see if it stops. Thanks UPDATE: I changed the coil and it is now working fine. The screws were not as tight as they were when I made the coil but they seemed to be still making a good connection. But after changing the coil and having no problem, there must have been a loose connection. Thanks again VapingBad. -
I'm using the hCigar VT200. I have a 0.08 ohm NI200 coil in an Steam Crave Aromamizer tank using my own coil in the RBA section. Watts are set to 27.3 and the temp is set to 420 degrees. As you can see in the graph, I take 1 hit and everything is perfect. When I take the 2nd hit, the coil doesn't fire and Evolv software says my coil is at 800 degrees. So I have to wait a while till I can take another hit. Does anyone have any idea on how I can fix this? Thanks in advance -
Awesome thanks Lilpetabread. Most appreciated.
Jaquith, are the numbers I posted correct or not? Or at least close? I was just trying to help RonS is all. Sorry if I selected information from someone you dislike. And YOU mentioned his name, not me. lol - I just gave the source of my information for verification purposes.
