bingbling
Everything posted by bingbling
My DNA 200 (HCigar VT200) is going bonkers
bingbling replied to bingbling's topic in DNA 200 and 250
I see. Might give it a go then, and its not a fortune lost either if it sux dit. Its becomming apparent. the battery is dying. When at 100-50% charge the vape is alright. But below 50% the vdrop is significant to the the point where the vape is below subpar. Its dropping to 3,0V at 50% charge. Luckily I have an rdna40 as backup. My builds are all titanium though, so I gotta rebuild some atty to kanthal I guess. I refuse to use Ni200 lol. I never could get a satisfactory vape with nickel. -
Fasttech carry this: https://www.fasttech.com/products/0/10023554/5088900-authentic-hcigar-vt200-replacement-1300mah-li-po Looks like the real thing. However, since I know that battery sux I'm not sure I want to buy that. I might look in to a new device instead, after x-mas when I am not broke haha. Not sure what one though. -
Yeah it's set at 3.41 because the battery sux, and it's getting unbalanced below that. Could very well be a dying battery. I am gonna change the Wh capacity and see what happens. I'll check the device moniter during a puff, what voltage drop would be acceptable, and what vdrop is a dying battery? If I can't get this sorted I guess I will get another device. Edit. I took your advice and changed the Wh. The weird thing is, now it says it has 1% charge, it had like 75% before I uploaded the settings? Here's a screenshot Edit no2. After letting the device charge for about an hour it jumped from 9% charge to 100%. Now I am gonna see if the meter stays "normal" and not fluctuate 20%. -
Well, the thing is I have been running the exact same settings for a year, and its been spot on. Until now that is. I haven´t changed a single thing. And about the incorrect resistance reading, it doesnt affect all my attys or builds. And yeah I know ur thinking its probably the build/connections that are loose or something. And I thought so too, but I have confirmed the actual correct reading on both a 2nd device (vaporshark dna40) and with my USA Ohm meter, and it always reads the same resistance, its weird rly. If the connections were loose there should be some variance on those two units as well. But its just the DNA200 device that gets the reading wrong sometimes. And its not like its just a tad off, its off by alot. The build that is currently giving me headache is a .17ohm, and that one reads between .17-.22. Anyhow on to the rest. Here's the screenshots u asked for: -
Hey. I've been having weird issues with my device for a while. Three things mainly. Firstly the battery meter is acting weird. What's happening is I set it to charge lets say at 0% and charge it to 30% for instance. Then I unplug and vape for a bit and let it rest. Then after a while, like a few minutes when I fire it up again, the battery meter suddenly says I have 50% battery instead of the 30% I had when I unplugged it. And its always off by 20%-ish. Secondly since this started happening the device rarely signals "Weak battery", the vape just gets very weak/no existant so I know the battery is down, but no weak battery signal. And lastly, the device sometimes fails to read the correct resistance when switching attys/builds. And I have confirmed a numerous times that the connections are tight, and my other ohm meters reads the resistance correctly. What gives? Is there anything I can do? Should I do a soft/hard reboot? -
Well, for ease of use its "needed". Not everyone wants to go through the hassle of setting up a VM or a secondary OS just for escribe. Personally, I have both a PC for gaming etc and a Macbook Pro for couch-surfing. So I am not really in "need" of a Mac version. However I would still like one for the moments when my PC is inaccessible, and for convenience.
Don't quote me on this, but I am almost certain I read in one of the threads somewhere here that there are plans for a Mac version, but not in the immediate future. Possibly in 2016.
Doing all the testing and setup of a DNA 200 Mod.
bingbling replied to LarryLenz's topic in EScribe, Software and Firmware
Kanthal -
You do not want to open the file as it is indeed of a type that has no association. You want to go into escribe and select File and Open to open the file.[/QUOTE] Well, no entirely true. Both my work computer and home computer has the *.ecig file associated with escribe, and doubleckling it opens it. So both methods work. However this has been solved. I will quote myself from a few posts above.
I spoke to Ari, the author of the file about sharing it, and he felt it was better you get it directly from the source so he can provide support and updates for future escribe versions. I will respect his wishes and not share it here. You are welcome to join the Facebook group "Dna200 modders", there you will easily find the posts from Ari containing the settings file and support for it.[/QUOTE] Why not contact Hcigar and get their file after all they made the device. Ari's file was modified by Ari thus different than Hcigar's file. Go to the source, or at least that is my take on it. Good luck.[/QUOTE] That would of course be the ideal solution, if HCigar had bothered with calibrating the device from the start, which they have not. They ship it with evolv defaults.[/QUOTE] that is all well and good except not all vt200's are the same, each battery for instance is not identical and the import you get may not be ideal for your battery .....using evolv defaults you get the experience tuning your own device using the analyzer's in escribe and building your own profile ..... a lot quicker than waiting on someone else to do it[/QUOTE] Yes, your are correct, not all VT200 are 100% identical and the battery will have minor differences. I did run the battery analyzer myself, and I measured the mod resistance. I have my own wire profiles setup etc etc. So I have gone through the process of setting things up. I wasn't looking for a "quick and easy" way to setup the VT200. This whole thing started out with me wanting to inspect and try Ari's settings out, and see what difference it would make. Ari has made some valid arguments in the comment section of the dna200 modders group on facebook, as to why he made the settings file. I am not going to get into the technical stuff why he did it, he is a lot better at explaining that than me. Anyone interested is welcome to join dna200 modders group and read the comments or ask him.
That settings (ecig) file was from me. And the 316L wire profile is for stainless steel, not Nickel. So you should not use that one with nickel coils, it will be way off. Actually all the wire profiles preprogrammed in that file is exclusively for Sweetspot Vapors wires, and should not be used without those particular wires. Its better you use steamengines wire wizard for generating csv-files for each of your non-nickel wires. All the other settings in the ecig-file is valid though. However I changed the mod resistance from 0.01 to 0.0045.
+1 Would have saved me some headache
*bump* The mystery has been solved. Me and Ari have been discussing this quite a bit today. And after some experimentation we found what was causing the issue. The problem was the date/time format. I am in sweden and I run an english OS Win8.1Pro with swedish keyboard lauout and swedish date/time format. And the calibration file from Ari contains timestamps in US format which couldnt be properly handled by escribe when I was in swedish date/format in the OS. So what I did was switch to US date/time format - started escribe - loaded the calib file - uploaded it to the device - disconnected - switched back to Swedish date/time format - started escribe and downloaded the settings and then resaved the file. Now it loads just fine for me in swedish date/time format.
File is OK, not corrupted etc. It has been confirmed by a number of people, both mine and Ari's copy of the file(s). I am going to try a few different possible solution later at home. It might have something to do with localizations within the OS. I will report back later.
Please see this thread for details: /topic/67314-topic/?do=findComment&comment=905855
*bump* So I tried opening the file on my work computer, same thing Can't open - "Unsupported file format". Could some knowledgeable person please help me? This is looking more and more like a bug in the software, maybe due to some localization? I work in IT but I am not a programmer so I can't debug this. Maybe someone from the escribe software developer team could assist?
Yeah I know how to open the file haha I've been around computers and such for the last 20 years or so, I work in IT tech/support business reapairing/building computers. So I am fairly tech savvy The issue isnt "how" to open but to get it to open without the error. When I try opening the file, no matter which way, doubleclick or open it via the File menu, it throws the error "Cant open - Unsupported file format". Thats what baffles me since I know the file is OK, and my escribe works in any other way. But the file simply wont open. Its an enigma, and its driving me nuts! I am going to try it at work tomorrow morning.
Have you tried from a different computer? Send the file to me in a message and I will try it, if you want to let me have a go at it? [/QUOTE] No I have not tried it in a different computer yet. I only have access to one PC and one Macbook at home. And its too much of a hazzle to get escribe running on a Mac. I will however try the file at my work computer monday morning. I can send the file to you if you want, even tough I know for certain there is nothing wrong with the file. James the admin here has confirmed it working, and so has countless other people from the closed facebook group I got it from. The file throwing "Unsupported file format" error for me simply makes ZERO sense. We all have the exact same version of escribe and the exakt same version of the ecig file. I can't for my life figure out what is wrong. And even if I were daft beyond belief there simply is not much that could possibly go wrong opening the file I alos tried uninstalling and reinstalling escribe, same problem. I ran it as admin and normal user, no difference. I am on a Windows 8.1 Pro x64 machine, eng version with swedish keyboard layout if that could possibly be a factor. I saved my own custom escribe settings file earlier, just to try it out. And that one loads just fine, not that it does me any good though lol
Is there any way to debug why I can't load the ecig settings file? Perhaps a way to log whats happening in the background to see why and what makes it fail? It seems I am the only one who can't open the file. Its really weird.
Actually it's none of the above. It's a *.ecig file, the filetype escribe defaults to when trying to open it with FILE-OPEN. I was under the impression thats the way to import the settings. I have tried to open it with file-open and load profile. It's supposed to contain a complete calibration of all settings, including battery analysis/battery discharge/cell soft cutoff/mod resistance/case analysis/wire profiles etc etc. I got the file from a closed facebook group, and I am not sure whether Ari agrees to making it public. I will send it to you in a PM James.
Ari from sweetspot vapours has been kind and created a proper calibration file for the HCigar VT200. But I can't get it to load. I am getting "Unsupported file format" when trying to open it. Others have reported it working, and the response to people who have had the problem has been given the advice to install the latest version of escribe, but I already have the latest. What am I doing wrong? I am trying to open it with FILE-OPEN. Edit. Not entirely sure but it looks like the reference by Ari for "the latest" escribe is actually the second to latest escribe.
If I recall correctly, my observation during the test was, the test terminated when the voltage dropped below the Cell Soft Cutoff under load. Mine is set to default 3.09V, and I am almost 100% certain I saw the graph dipping to 3.08V and then terminate.
