cobalt327
    United States
    Simeiyue SMY SDNA75 75W mod
cobalt327's Achievements
  1. I have some on order myself, will work out a viable TCR and go from there. I'll post my results to see how they compare.
  2. Actually it seems to be an alloy of the 2 elements. At what ratio is unknown to me- my only experience w/any similar alloy is the Marchon Flexon eyeglass frames I bought several years ago. They were the "memory metal" that was hyped by the manufacturers. Link to the wire [url=https://www.fasttech.com/search?Tini]HERE[/url].
  3. Anyone have experience w/this wire? Pro's, con's, TCR?
  4. The mod case would be used as a ground path. Assuming identical mods other than cast vs. milled (assume 'milled' means billet), both having proper connections, correct gauge wire etc. and all else being equal between the two examples, is there any validity to:
  5. "Evolv Experience™ 20W DNA Microchip"? wtf? Guess I need to get out more often. haha
  6. Have you tried using slightly spaced coils? Some wires do better that way- I personally haven't used those wires but it's something to consider.
  7. Default profiles installed on SNY SDNA 75:
  8. I guess it's a matter of cost vs. demand, but I hear what you're saying. I'm guessing you do have the puff count displayed on the screen.. Me, I'm a "time" person- I would like to have the screen display cumulative vape/fire button 'on' time ("last puff" time is the only option, it's useless to me) w/o having to go into escribe, and for it to also be resettable from the mod. I use this on other mods and it is one way to see if there's anything unusual going on, like if the battery is discharged before I know it should be, and for how changing settings effect battery run time. That said, I'm thinking you and I must be in the minority! haha
  9. Do'h! Appreciated...
  10. Until the experts reply, I don't believe you can reset from the mod. You may well already be aware of this, but you can reset by going into the Device Monitor and selecting "Reset Statistics", though. This resets all the fields, including the puff counter.
  11. Using a SMY SDNA 75 and liking it very much. Want to know how to check what firmware version I'm running. Thanks in advance.
  12. ---------------
  13. Be sure the cable has data link and is not just for charging. Paraphrasing:
  14. I'd guess you are, but always use the sleeve that centers the 18650 battery in the battery tube.
  15. cobalt327
    Cotton Test
    Excellent-thanks.
