dedone
  • Full Name
    daniele
    italy
    DNA200-DNA75
dedone's Achievements
  1. Same issue for me, any news about it?
  2. Vaping.......YOU'RE THE MAN!!!!!!!! YOU SAVE ME!!!!!!!!!! All the problem in in the srew under the white sponge, i had removed the sponde and tight the screw, and now all is working perfect!!!!!!! THANKS THANKS THANKS!!!!!!!!!!!
  3. Where is this screw? It's accesible without avoid the warranty?
  4. This is the official reply from Wismec about my problem: Dear friend, Thanks for your email and sorry for the delayed reply.As for the problem you mentioned, kindly suggest you contact Evolv for help since our chip is provided by them.Have a nice day. Best wishes! ShirleyMarketing Department I've send the email not to the marketing, but to service@wismec.com (as write in their website fot techincal support) I 'm starting to upset! ok....and now!?!?!?!!?
  5. It only has 2 balance wires, number 1 & 2, GND & 3 are jumpers from the battery connection pads, but the negative battery connection goes via the ground tab to the top left ground point on the board and the positive is wired. So as I said above there is a possibility the GND balance connection is higher resistance and why I asked if it is common that cell1 is the low one.[/QUOTE] Sorry Vaping, i'm not so "technical", does it mean that i have to send it back (if Wismec reply me) or i can do something to fix it by myself?
  6. @Opako I'll let you know what wismec says
  7. As VapingBad said, this is the worst situation I've just write to wismec and i wait for a reply....
  8. ok, i've try with the magnet, i've try to clean contact and i've try to swap batteries...nothing Now i'll try to write to wismec....
  9. i've try to change the position of every battery, but it continuosly giving me same result on cell 1....so this is not a battery problem.What i've to do?
  10. Hello Jaquith. Could you please do the Sony VTC5 profile. I would like to see what you get. I like your input and how you do your profiles. Thank you.[/QUOTE] Me too please!!!!!
  11. Vaping you give me a relly BIG BIG BIG help!!!!!!! I just reduce a lot the difference with the point that you give me. Now i'll try with the magnet and hope to clear this small balance difference. Only hope that it isn't a problem of the mod.... I'll let you know. THANKS again!!!!!
  12. ok, understand. But what i have to do now?
  13. now seems to be better (it doesn't say me nothing at the moment). I clean the battery and mod contact with alcool and i change also battery position
  14. but all the batteries are fresh (VTC5). I've charged the first time with the Nitecore intellycharge i4, and the direct with the mod. I aslo show you my setting
  15. Hi all, i've try a loto of solution, but without any result. My problem is that when i reach 47% of battery chargen it start to say me "check battery" wheni fire. I can't understand why.... I hope in you help!!!!
