tramog
Everything posted by tramog
  1. Thank you @retird
  2. I will do it. Thank you @Wayneo.
  3. Hello, a question for Evol: is an upgrade of USB to type C planned? Thank you.
  4. Upload the default theme and try again with 316L.
  5. Try setting the Warmth to a minimum.
  6. Thank you. I will also do a trial. It remains a "mystery" about its purpose and why it was inserted under "Ohm Lock Range". This check is only on the 75C. In the old 75 B/W it does not have it.
  7. Version 1.2
    398 downloads
    DNA 75C Theme - Replay Mode for Lost vape Mirage Note: In "Profile" inserted TC on / off. It is possible to activate / deactivate the tc directly from the box. Temp. Board and Temp. Room have been added to the main screen. You must have the latest version of Escribe and the latest 75C DNA firmware installed. Before loading it on the box, make a backup copy of your old theme. To activate / deactivate the Replay, go to: Menu -> Replay Mode Report any errors, corrections, changes or additions. Thank you.
  8. Thank you. So you want to say that if I do a coil in Kanthal this does not work even if I do not use the temperature control but only VW? I do not understand the purpose.
  9. What does checking this condition involve? Is it related to Replay Mode or is it generic? Thank you
  10. Version 1.2
    694 downloads
    DNA 75C Theme - Replay Mode. Note: In "Profile" inserted TC on / off. It is possible to activate / deactivate the tc directly from the box. Temp. Board and Temp. Room have been added to the main screen. You must have the latest version of Escribe and the latest 75C DNA firmware installed. Before loading it on the box, make a backup copy of your old theme. To activate / deactivate the Replay, go to: Menu -> Replay Mode Report any errors, corrections, changes or additions. Thank you.
  11. Have you tried to change the USB cable?
  12. I confirm, even my Mirage has an internal resistance of 0.004 ohms.
  13. My Mirage 75C has an internal resistance of 0.004 ohms and, so far, it did not give me any problem.
  14. Any technical explanation on how the Replay Mode will work? Thank you.
  15. Nothing serious ... but on my box with DNA 75C known that the battery charge level stops at 98-99%, never ever 100%. It also happens to me if I insert batteries previously charged with an external battery charger. Performed the "battery test" for both batteries (Samsung 25R and Sony VTC5A) ... nothing, the boxes signal me to charge battery (green led) and 98% charge level. Does it happen to you too?
  16. Version 1.0.0
    242 downloads
    Theme for Lost Vape Mirage 75C. Feel free to post any problems or inconsistencies. Version: 1.0 Date: Jan 31 2018 For Boost on Watt-Mode install EScribe Suite 2.0 SP8 for international customers. Download: https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/
  17. It depends on how the profile is set. For example: if you choose kanthal or Watt automatically you can only set the punch.
  18. Version 1.2
    200 downloads
    Horizontal full options theme. Feel free to post any problems or inconsistencies. Version: 1.2 Date: Nov 14 2017 For Boost on Watt-Mode install EScribe Suite 2.0 SP8 for international customers. Download: https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/
  19. Escribe theme designer. Preheat: How is it possible to choose between Punch or Temperature? Is not there an option to do this?
  20. Version 1.3
    166 downloads
    My first full options theme. Feel free to post any problems or inconsistencies. Version: 1.3 Date: Nov 13 2017 For Boost on Watt-Mode install EScribe Suite 2.0 SP8 for international customers. Download: https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/
