tramog
1 Follower
    Italy
    DNA 75C
tramog's Achievements
  1. Thank you @retird
  2. I will do it. Thank you @Wayneo.
  3. Hello, a question for Evol: is an upgrade of USB to type C planned? Thank you.
  4. Upload the default theme and try again with 316L.
  5. Try setting the Warmth to a minimum.
  6. Thank you. I will also do a trial. It remains a "mystery" about its purpose and why it was inserted under "Ohm Lock Range". This check is only on the 75C. In the old 75 B/W it does not have it.
  7. Version 1.2
    403 downloads
    DNA 75C Theme - Replay Mode for Lost vape Mirage Note: In "Profile" inserted TC on / off. It is possible to activate / deactivate the tc directly from the box. Temp. Board and Temp. Room have been added to the main screen. You must have the latest version of Escribe and the latest 75C DNA firmware installed. Before loading it on the box, make a backup copy of your old theme. To activate / deactivate the Replay, go to: Menu -> Replay Mode Report any errors, corrections, changes or additions. Thank you.
  8. Thank you. So you want to say that if I do a coil in Kanthal this does not work even if I do not use the temperature control but only VW? I do not understand the purpose.
  9. What does checking this condition involve? Is it related to Replay Mode or is it generic? Thank you
  10. Version 1.2
    697 downloads
    DNA 75C Theme - Replay Mode. Note: In "Profile" inserted TC on / off. It is possible to activate / deactivate the tc directly from the box. Temp. Board and Temp. Room have been added to the main screen. You must have the latest version of Escribe and the latest 75C DNA firmware installed. Before loading it on the box, make a backup copy of your old theme. To activate / deactivate the Replay, go to: Menu -> Replay Mode Report any errors, corrections, changes or additions. Thank you.
  11. Have you tried to change the USB cable?
  12. I confirm, even my Mirage has an internal resistance of 0.004 ohms.
  13. My Mirage 75C has an internal resistance of 0.004 ohms and, so far, it did not give me any problem.
  14. Any technical explanation on how the Replay Mode will work? Thank you.
