Darth vapes
Everything posted by Darth vapes
will only work on unlikely coils.....and only on 100c and 250c..75c doesnt have that option
Fireluke 3. No replay with SS904 or TC
Darth vapes replied to Darth vapes's topic in Replay and Atomizers
All good 👍 -
Hi bill thanks for the info..yes I'm using Zeus x .but I only use 316 in that..so no problems there.. it's my fireluke 3 that uses the 904L coils which give me problems for replay and I guess that would go for tc as well..I think the fireluke 2 has a ss316 coil..I might hunt one down and try those ..I have a nexmesh sub ohm tank as well..not the pro version..it has a 316..but the tank leaks due to poor coil design. -
Update..replay no longer Reading 904L...I swapped out a coil of the same type and now it won't read..so no save puff..I thought replay was supposed to detect a temp coil..so tired on my 250c same thing..no save puff..only works on my ss316L home made coils...even after importing 904L profile..and putting that on device materials still won't recognize that it is a temp sensing coil on replay...am I doing something wrong? -
Yes I found TCR for ss904L..and saved that file..saved it to escribe then transferred to the mod..then selected it to use with replay..under the material tab..still won't let me save puff...so I reset the mod to factory.. reinstall the theme that I like updated back to sp45.1 experimental..and then allowed for unlikely coils..and it works...tested this out on replay and it does still work...not allowing me to burn the freemax fireluke 3 ss904L coil -
yes it does..if you go back to the old version...its just sp45.1 where it wont work for me on replay...But it does solve my firing problem..not 1 miss so far -
just tried this and it worked...but only worked on allow unlikely coils...Thanks -
So I installed the sp45.1..which solved my firing problem..but now replay not working... it's not reading the ss904L coil..so won't let me save puff... also TC it's working but I'm not convinced it's reading the material... TC feels like wattage mode
Ok so home from work and tried the sp 45.1 experimental version that you speak of...i was using the sp 45 only...Ok so now its working!....i can let the screen time out..then take a puff and it vapes as it should no more weak puffs so far.... where as before it would always give me a weak puff after the screen goes blank which i think is 10 seconds at a guess...now even after 5 minutes of sitting idle i fire it works...So to confirm the sp45.1 experimental version has solved my particular problem...Thank you!
Yes sp45.. international version
Something thing happening with my Hyperion.. keep getting weak puffs doesn't matter what tank it is..or coil type in way of material..low battery or full battery..old service pack or new service pack...what I have noticed is it mainly does it when screen is off...if you click first to light up the screen then fire it's fine... otherwise you get a half wattage puff...even in TC..using 316L
This is to do with the Apocalypse RDA Gen 2 24mm
Darth vapes replied to Darth vapes's topic in DNA 200 and 250
As some of you may know the o rings are really loose...i found that if you use the ONE spear o ring for the airflow barrel it works nice and tight without being too tight...take the top o ring off and replace with the barrel o ring...lube with juice and let it settle in...leave the bottom o ring on. -
Triade battery door not closing all the way with vtc6s
Yeah i was tossing up weather i should just get 3 more h2's...but i wanted a battery that would give me the 3000 or very close to it..plus i wanted to get some 6's...before too many fakes start hitting the market..as for the door..it's only a small line of green on one side and thats in natural light...a normal person i think would fail to see it i reckon...lol....but i already knew that some batteries have a tough time in the triade...i just never suspected the vtc6's would be the one!..As all the other sony's i have are fine 4.. 5.. 5a's -
Thanks giz!...was wondering if i'd picked up some fakes!...as for the door it's no drama..seems the vtc6 is alittle different to 4s or 5s not cheap here in New Zealand..at $20 per cell...the tops of the vtc6s seem a little different to the other vtc's...as in the ribbing ring marks around the top so had a look on you tube and they seem to be the same from what other people have....the first 3 i'm using now in the triade..The other three have gone through the charge and now discharging then will charge again so i guess time will tell...cheers giz for the heads up on the vtc6's -
By the way i do mean 3.55 volts fresh from the box when charging started...not finished -
So battery door won't close all the way with vtc6s...but does with hg2 and vtc5s.....Also i bought 6 new vtc6s three i charged i think the voltage was around 3.55 somewhere around there..but the Mah only got to 2340...is this normal for the first charge?....the other 3 i'v gone straight to a refresh cycle..still waiting for it to finish i'm hopeing i'll see 3000 when finished...although i have seen them go over 3100mah...hopeing there not fakes! -
thats a good idea!...but it's not really that lose...at all it will never come lose on its own...you just cant tighten it till it stops is all...it's designed that way i'm sure
cheers! giz!
Also would love to see the information stay on screen untill the next fire...such as the volts and amps...but no!..you have to hold fire button down to get a jumping volts and amps...even joyetech and others give you 1 second to read that fire value before it disapears
Mod resistance should be set from factory.....or i mean to say Mods from lost vape should be tuned..each one of them and then stated in the manual say that this very mod has been well tuned...that way people like us don't have to guess weather it's off or on should i play with it? or not?.....I also hate looking at my screen and it shows me coil of .21...when i know it's a .20..that right there fks me off...and yet i should'nt change it cause one might fk up the TC on the thing...either way your fked
would have been nice to see some wood above the vent holes...Almost looks like that was the idea at the start....mybe in the next version
I just carefully took it out...and come out with no problem...then screwed it back in slowly again..also went in with no problem...so im not gonna fk with it anymore....it seems to get to a depth and stay there...even squeezing the battery sled with my other two fingers while tightening doesn't make a differance....But in saying all that it diffenitly won't work itself out over time..i was being a bit OCD with the wee gap...mind you the same gap is at the top as well..lol so it's even!
Yeah it does...my bottom screw is nearly tight but not super tight like the others....some for the top north screw as well..both deal to the single battery on the outside so yes it's for the sled surely i can't be that unlucky to get two striped screws otherwise..but who knows!
Mod resistance are both set to 0.004 from factory
