Darth vapes
Everything posted by Darth vapes
Have you guys noticed that the bottom screw does not tighten?..or is it just mine....it's not really lose but it just keeps turning.....same with the top screw as well...the north side of the 510...but the other two are as normal....i'm thinking that this is how they have designed it...for what reason i'm not sure....the two lose screws i did not try and take them out....just tryed to tighten them...why?...was trying to mainly close up that bottom gap just a little more.
Also finding the Triade hitting harder at 70w than the Therion at the same wattage...that will be the third battery helping out i guess.
Yes i did..lol...did not see that...so if i don't check that it will stay wattage Dominant
Are i found the problem!....seems in screen mode it was set to last power instead of (temp) which is the standard for the middle screen!...now it shows watts that i have set...But why does it not show temp?...should it be watts on the right plane..(the main screen)..and temp in the small middle left plane?....i mean if i picked temp which i did then why does it show wattage?
on my therion i can adjust the wattage in tc...then when i vape it shows in the left plane which is correct...but with my new triade i do the same thing but the wattage changes in auto mode...cant seem to set the watts to 75 and stay there..if i ajust the temp lower then the wattage will go lower as well...if i up the temp then the wattage will go up as well...so its auto ajusting...Why?..and how can i stop this from happening?
It makes me nervus every time i pull my batteries out of my Therion..i check the positive side and see the dented but not broken!...soft shell......in fact! before i bought the Therion which is only a week ago i first bought the x cube ultra.....that was my very first mod!.....did my battery research on vaping as you do when your new the vape game....But dam!...putting those batteries in and out od the x cube ultra was really biteing into the battery skin!....so only after a week i went in search for a mod that looked good and had dual 18650s...and went for the Evic primo...because of the drop in style of battery door...much better plus had sleeves to seperate the batteries.....But the mod was sht! with jumping out of tc and getting way to hot to hold...so i deemed it unsafe for my liking....so went and bought the Smok G320!...same battery door..nice srceen!...was really happy with it...3 batteries!..all day vape!...high power if and when you want it!....small for the size!...But screen died after 1 and half days...so i got a replacement!...this one was all good for about 4 days!....Then battery A would not drain battery B and C were fine!...Yes i could have used it as a dual 18650 and still get the 220Watts...But no long battery life....so i thought fk it!....Whats out there that will last!..and work as it should!...Now i already knew about the Therion 75 133 166..loved them the most...but no one had them in stock!....and there $250.00 here in New Zealand...x cube ultra still 119.00...primo 75.00..G320..109.00...and the black therion 250.00...so i thought just get the therion and be done with it!...so got the black one.....the battery contacts arnt AS ruff as the x cube....LOL sorry for the long life story post!
You can almost feel it coming!...some one will come out with 18650 style vape battery...with a hard shell not a soft skin that can tear and cause a hazard!..and a more stable vape style
Thats true!...lots more to think about now!....with vapers anyway!
Yeah..this is true!...it not a pefect match....18650s not designed for Mods....was designed for laptops and such....so we make do with whats at hand
Never mind on the ecig battery file! i have found your one!...cool!...but i have found that even the LG H2 and the sonys arnt really the MAH that they should be..always around 100 less or! even less!..and thats after doing a refresh cycle of the batteries
But i will take it apart when i get it and clean it out!
I dont actully clean my tanks out between juices anyway....i just top up to what ever flavour i want next.....and sometimes i like to mix my flavours and discover somthing new!
LOL..Yeah i know!...should have been a flat top!...not a philips
Also been looking for a good vtc5 battery ecig file for 2 vtc5s...the one i downloaded off of here is not quite right...battery low comes on at 15%...and that was using 70 watts all day...and yet the LG HG2 profile i also got from here..works to well!..as in it keeped fireing when battery bar was competely empty!...for how long?....dont know?...i had 4 or 5 more puffs then switched to vtc 5s....i have my soft cell set to 2.7..i dont want to go any lower than that......Batteries are always charged on my skyrc mc3000....which showed the flat vtc5s around 3.32 volts...also i always charge my 18650s at 0.75Ma....So looking for a good vtc5 file that has been setup using Therion 166
Yes thats true...been watching a few reviews on it as well...seems once you get the wicking right it works really well..so should be a good tank..its about $48.00 here in New Zealand which makes it pricey..so hopefully it runs well..keep my wicks nice and short as possible
Had a look around and decided to go for the Avocado 24
Ok Thank you!
Hmm!...Might have to start thinking about getting an RTDA...Any recomendations?...Would like at least 5ml capacity but as short as posible
Also im starting to think that my coils could be a little to close to the out edge of the tfv8 rba and cauing the rime to get to hot...just a guess
Yes way to weak...yeah i know why the warning comes up but i dont understand why?.....works well in wattage mode at 65watts..although the ohms keeps changing in wattage mode..in temp mode the ohms is stable..@0.37...checked with atimizer test as well and its the same
just build a 0.37ohm dual 316L with 26ga..@3.0..10 wrap...So my problem is when in temp mode it keeps coming up with temp protect warning...and thats anything between 30 watts and 60 watts..at 450F..im using TCR..0.00093 which is for Stainlees steel....im i doing somthing wrong?
Hi guys i;m new to this mod and forum...and my question is in the mod tab you will find (mod resistance!...mine shows 0.004......should there be any resistance at all?...it can be changed...should i set the 0.004 to 0.000?...i guess it doesnt really matter to much. But just to round it off say!
