shrahman
1 Follower
  • Full Name
    Shehriyar Rahman
    Bangladesh
    DNA40, DNA75, DNA200, DNA250, DNA75C
shrahman's Achievements
  1. That is the eScribe 2.0 SP13 beta which supports the 250C. I haven’t seen any further updates to this yet.
  2. Thank you, @retird
  3. You'd most likely have to rewire the battery cradle as well, since the Paranormal 75C is running in parallel, whereas the 250C will need the batteries in series.
  4. Is there an updated version available for macOS? I checked in the early software thread, and it only has SP12 available.
  5. When you upload settings to device, the Profile chosen in the drop down menu is made the active profile on your device, @thewarm.
  6. In device monitor, for the screen shot function, is it possible to get the values to be also shown the same way as a screen capture does? Both screens are from the same draw, first one is from eScribe and the second one is a screen can.
  7. I've not had any issue using a 2A wall charger and USB with a Therion 75C
  8. Vapedroid Theme by Ayman Azmy. I noticed the error when the mod was untethered. Haven't checked to see if the error is the same with the mod connected on USB.
  9. Think this may be a new bug? While adjusting running wattage on the mod, the preheat wattage changes as well. I took a video, but file size restrictions don't allow me to upload
  10. Thanks, dwaindablane. I'm assuming that since I'm using a DNA75 and not a DNA75c with eScribe 2.0, I should probably revert back to the older 1.2SP5a?
  11. Have the "Soft Reboot" and "Hard Reboot" options from the previous eScribe versions been removed? I can't seem to find them anymore in eScribe 2.0
  12. Would really appreciate if someone would be able to provide the CSV file for the discharge profile for the Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack. Thank you!
